wheel studs
Old Feb 21, 2015 | 07:26 PM
Natcox012's Avatar
Natcox012
wheel studs
OK so driving my 1988 f250 other day and rear lug nuts started snapping off and now looking for best bang for the buck wheel studs to replace them. I had to put nuts and bolts to get home. Cheap but yet good weight rating
Old Feb 22, 2015 | 08:25 AM
rolsmojave3's Avatar
rolsmojave3
Just go to your local Napa or whatever and get some studs and new lugs for it.
Old Feb 22, 2015 | 08:58 AM
Natcox012's Avatar
Natcox012
OK thanks didn't know if there were heavier duty for the same price but will do
Old Feb 22, 2015 | 12:40 PM
rolsmojave3
I'm not sure if they make a stronger grade without changing diameter or not. I would replace them and make sure the lugs get torqued to correct specs so you don't have to have them loosening and breaking more studs.
Old Feb 22, 2015 | 12:46 PM
eakermeld's Avatar
eakermeld
Examine your wheels very close. Running loose lugs will can damage where the nut seats in the wheel. If it is damaged, the nuts will not stay tight. You may need to replace the wheel.
Old Feb 22, 2015 | 03:20 PM
Natcox012's Avatar
Natcox012
Yea the rims got loose and damaged a little but still operates. Need to tighten better
Old Feb 22, 2015 | 03:28 PM
eakermeld's Avatar
eakermeld
Keep a very close eye on them and check them frequently for a while. If they stay tight, you are good-to-go. If they keep coming loose, even a little bit, junk the wheels before they kill you!
iochd
Oct 31, 2018 08:08 PM
GruesomeJeans
1978 - 1996 Big Bronco
Mar 23, 2013 01:03 AM
dark_flame221
May 4, 2010 09:23 AM
Welsch69
May 12, 2008 08:58 PM
timothy47129
Sep 4, 2006 10:43 PM
