Wheel Studs
Old May 9, 2008 | 05:01 PM
Welsch69's Avatar
Welsch69
Wheel Studs
Does anyone know where i can get the 1/2 - 20 thread wheel studs for my 1975 F250 that are longer than original so that i can mount my aftermarket wheels. Once I put on the new wheels, i don't have enough thread sticking through to put on the lug nuts. Thanks.
The front stud knurls are .628" and the rear stud knurls are .608"
Napa had stock replacement ones, but didn't know where i'd find longer replacement ones.
Thanks all.
Old May 9, 2008 | 07:48 PM
RJR99SS's Avatar
RJR99SS
something like this?
ARP 100-7703 - ARP Wheel Studs - summitracing.com
Not sure exactly what length you need, but summit has a whole wheel stud section to browse around...
Old May 12, 2008 | 05:18 AM
Welsch69's Avatar
Welsch69
thank you very much.
Old May 12, 2008 | 09:21 AM
75F350's Avatar
75F350
In many cases the studs do not have to be changed. You will need longer lug nuts, but not longer wheel studs.
Most aluminum wheels with a thick center will require a specialty lug nut that is available at any tire and wheel shop.
Acorn style wheel lug nuts are not correct, and you may just need some shank style lug nuts.
Using the wrong lug nut will result in an improper torque, and you run the risk of the wheel falling off.
Get the correct fasteners, and you will not have to replace all of the studs.
Old May 12, 2008 | 08:58 PM
Welsch69's Avatar
Welsch69
Thanks for your help. But i've already researched the lug nut style by taking my rims in to two different tire shops. The rims require the acorn style lug nut, but when the rim is put on the lugs, they don't stick through enough to put the nut on. The rims are American Racing Baja polished aluminum and the bolt holes are tapered, requiring the acorn lugs.
dannoman1
Mar 9, 2011 10:04 PM
81Bronk36
Aug 29, 2010 10:28 PM
Damon_Tirerack
Apr 22, 2009 11:07 AM
3414
Jul 23, 2008 04:45 AM
jasper
Oct 2, 2000 12:00 PM
