1978 - 1996 Big Bronco
Wheel studs/Lugnuts
Old Mar 22, 2013 | 09:15 PM
GruesomeJeans's Avatar
GruesomeJeans
Wheel studs/Lugnuts
So after my recent "tire falling off" incident, I decided I wanted to look into some better hardware. And by hardware I mean some real heavy duty wheel studs, and some heavy duty Lug nuts that would make it really hard for me to break or strip. I don't really know where to start with this, I was thinking about heading to AutoZone or something and seeing if maybe they could special order something but I kind of figured they wouldn't be able to.
Anyways, If anyone has any ideas I would be thankful.
Old Mar 22, 2013 | 09:20 PM
Opossum's Avatar
Opossum
How did it "fall off"?
Need to keep your wheels unmolested?
Old Mar 22, 2013 | 09:27 PM
GruesomeJeans
Eh It fell off from loose lugnuts but in the past when I put any real weight behind tightening the nuts, they twisted the studs apart. And being afraid to do that again, I didn't force them tight enough I guess. Pulling a front hub apart to replace studs is one thing, pulling a whole rear end apart to replace them is something I didn't want to do.
Old Mar 22, 2013 | 09:34 PM
Opossum's Avatar
Opossum
Came unscrewed fell off?
Uhm a torque wrench?
You have aluminum wheels so retorque after your first drive.
Replace with high quality studs and nuts and torque properly.
Get some of those nut locks dohickies, lots of different kinds.
Edit;
Pulling your rear axle isn't any harder, maybe even easier then the front. You, I'd guess just have never done it.
Damage the wheel or anything else?
Old Mar 22, 2013 | 09:44 PM
GruesomeJeans
Unscrewed I think
Have one, no extension for it though. The handle hits the sidewall not allowing the socket to get coo contact to the nut.
Looking into steel rims shortly.
That's what this thread was for. I don't know where to find high quality ones.
The locking lug nuts? That would be hard to get tight without breaking it.
Edit;
Never done it. I've done the front before.
The back side of the rim has a bit of gouging and the inner sidewall of the tire rubbed on the fender but otherwise nothing bad.
Pretty much I just don't know where to find these high quality lugnuts and studs. I would think Grade 8 would be good enough but I don't know, I don't know the grade of my current ones.
Old Mar 22, 2013 | 10:12 PM
Opossum's Avatar
Opossum
You really need to get an extension
Steel is better as far as this is concerned but not a big deal
You really just need stock replacements Napa should have some or here they are online 1978 FORD BRONCO Lug Stud
There is bigger, longer, etc. available but a pricey pain in the **** that you don't need.
There's companies that make things that go over the nut so they can't turn. There's race car type stuff and heavy truck type stuff (the green things you see) Really depends on your wheel what will work, but you really shouldn't need anything like that on your rig if you use good parts and a torque wrench.
To remove rear axle - If you look there are 4 bolts that hold your backing plate on. Just jack it up, take off wheel, brake drum, and those bolts. Then find a way to yank on the axle, a heavy chain on a wheel stud with a lug nut then used like a whip works well. Or if really stuck you can rent slide hammers from the auto parts stores.
Old Mar 22, 2013 | 10:21 PM
GruesomeJeans
I do need one, just haven't had money lately. With this new job I can get one. For now, my neighbor said to just borrow his when I need it.
I prefer steel wheels over aluminum not only for their strength but also the balancing. Using sticky weights on these aluminum rims doesn't work so well because they fall off easily.
Stock replacement studs? I don't know that I trust those anymore.
I remember seeing those green locker things on some of the semi trucks or garbage trucks.
I've seen the 4 bolts and my brother told me after those come off, I should be able to remove the axle. I'm sure I will think of something to get it off without renting tools. Should I look into replacement bearings as well?
Old Mar 22, 2013 | 10:28 PM
Opossum's Avatar
Opossum
Wait, what are you doing if you can't afford a simple 1/2" extension? Like 2 bucks at harbor freight, hell man I'll give ya one.
Old Mar 22, 2013 | 10:55 PM
GruesomeJeans
They were more than $2, also I had a few other things in my basket. That was when I was working 1 night a week and trying to save what I could. that was why I was at harbor freight getting the cheap tools.
Old Mar 23, 2013 | 12:02 AM
joewelds's Avatar
joewelds
Just my 2€ (that's supposed to be cents) but if your putting in your tires the stud should NOT "twist apart". I would think, however unfortunate, time to replace. Because now your unsure of your hardware.
Like I said just my 2 cent.
Old Mar 23, 2013 | 01:03 AM
GruesomeJeans
Oh I know, that happened on my fronts. I was tightening them with a wrench or something (I don't remember) and as I was tightening the stud it got tight and as I kept turning it started getting easier and then *pop* it broke. I was so pissed.... Since the PO of my truck is an idiot and lied about almost everything, I could see these studs being weak.
greenmachine86
28
Sep 23, 2016 05:21 PM
Natcox012
Feb 22, 2015 03:28 PM
Welsch69
May 12, 2008 08:58 PM
Recycleking
Aerostar
15
Oct 11, 2007 10:28 PM
johnnyj
Mar 31, 2000 06:16 AM
