Low Boost Problem
Old Feb 23, 2015 | 10:08 AM
  #46
POS Camaro's Avatar
POS Camaro
Well, it appears that my air leak is at the intake manifold. I got nothing on the boots or the intercooler. I just removed it because the donut o-ring was leaking coolant, not looking forward to trying it again.
Old Feb 23, 2015 | 10:30 AM
  #47
11jjonn's Avatar
11jjonn
Oops, My Bad --
I forgot to ask you the First Question:
What did you work on just prior to malfunction appearance ?
(as in, "Boost was OK until I did This ........, now I have a new problem with it")
Old Feb 23, 2015 | 10:39 AM
  #48
POS Camaro's Avatar
POS Camaro
That question is harder than it appears. After doing the intake I noticed that the hot side CAC boot from the turbo to the pipe was torn. It didn't feel alot different before than after because of that. I also didn't have the SCII before so I don't know normal yet. Working on it though.
Old Feb 23, 2015 | 10:50 AM
  #49
11jjonn's Avatar
11jjonn
Please let me know the solution, so I might put this in my "memory bank".
fyi - my Boost (according to SG2 and Glowshift gauge) maxes at 22, unloaded
Old Feb 23, 2015 | 07:27 PM
  #50
POS Camaro's Avatar
POS Camaro
It will be a while before I can attempt to tighten the intake manifold. Getting chilly down here.
Old Mar 14, 2015 | 05:13 PM
  #51
POS Camaro's Avatar
POS Camaro
I finally got a chance to check out the intake gasket and other possible issues. I found that I had an exhaust leak at the turbo inlet and at the EGR cooler. I also replaced the intake gaskets from Fel Pro to Motorcraft and followed the Ford torque sequence and spec. I now have power from 1/4 throttle to full throttle and she builds boost quick. Max boost I saw on the test drive was 18.5 PSI as opposed to 13 PSI if I was lucky. It also gets to the higher boost almost instantly vice only in 4th gear like before. I did the turbo relearn and got up to 21.5 PSI. She is way more fun to drive and I foresee a stupid speeding ticket in my future.
Thank You for all your assistance, it is much appreciated.
Old Mar 14, 2015 | 07:15 PM
  #52
11jjonn's Avatar
11jjonn
Looking good -- Glad I was able to be a help to you, that's why we're here on this forum.
Old Mar 14, 2015 | 09:42 PM
  #53
firedaniel's Avatar
firedaniel
Visually check the harness. Mine was obvious once I figured out while cranking had low rpm reported. The pigtail just as it goes into the sensor the wire was bare. Mine never threw a code or anything just occasionally wouldn't start. I was going crazy trying to figure it out!
I think it says 1 once they sync.
Old Mar 16, 2015 | 05:38 PM
  #54
Jmoen7's Avatar
Jmoen7
You're getting up there but you're still missing out on about 6 fun points. (6 lbs of boost) properly sealed system can see 28 psi, and although the turbo can make alot more, the computer keeps it there. Keep chasing leaks. But atleast now it's driveable
Old Mar 16, 2015 | 06:54 PM
  #55
POS Camaro's Avatar
POS Camaro
Does it get to 28 PSI unloaded? I was planning to tow my trailer with it soon and see if it made that pressure with more load.
Old Mar 17, 2015 | 01:59 AM
  #56
11jjonn's Avatar
11jjonn
I did a quick WOT run yesterday (to dry off after a hand wash) - unloaded, managed to hit 23 psi (then ran out of road in 45mph speed zone !!)
Old Mar 17, 2015 | 05:30 AM
  #57
POS Camaro's Avatar
POS Camaro
I checked codes and I have a P132B. Looks like I do still have an air leak somewhere. I removed the EGR valve and cleaned it up, didn't have the gasket or o-rings to replace. That will be the next thing to try and seal.
KIDkiser
May 12, 2014 06:38 PM
Pitcrw6
Jun 17, 2011 12:09 PM
MTMike
Jul 24, 2006 07:09 PM
Silverbullet01
Jan 21, 2006 09:54 PM
dtruzinski
May 30, 2004 12:04 PM
