Need help with Boost gauge in Torque Pro Android
Old Feb 20, 2015 | 12:50 AM
chetspencer's Avatar
chetspencer
I've searched Google / YouTube for hours and just can't find the correct setup for Turbo Boost.
I need to know what settings you guys are using for Boost please.
Which PID to use?
Boost Calculation Method?
Boost offset =0?
Otherwise I'm very happy with Torque Pro! Bye Bye Scan Gauge II
Old Feb 20, 2015 | 01:04 AM
diesel_dan's Avatar
diesel_dan
First of all make sure you've loaded the Ford specific PIDs
PID: 221440
Long Name: Boost (that's what I use)
Short Name: MAP
Min Value: 0.0
Max Value: 30.0
Scale Factor: x1
Unit Type: psi
Equation: (((A*256)+B*0.03625)-BARO()
OBD Header: Auto
That is what I have in mine...
Old Feb 20, 2015 | 01:36 AM
LindenBruce's Avatar
LindenBruce
And how do you load the Ford PIDS? B.
Old Feb 20, 2015 | 06:57 AM
Will Bite's Avatar
Will Bite
Go to settings/manage extra pids/sensors then click on menu then add predefined set. Then click on Ford pids.
Old Feb 20, 2015 | 09:42 AM
chetspencer
Thanks for the info guys! Can you let me know what you have set for:
"Boost Calculation Method" and "Boost offset"? Appreciate to help.
Old Feb 26, 2015 | 06:57 AM
Will Bite's Avatar
Will Bite
Default or Prefer MAP
Old Feb 28, 2015 | 08:47 PM
chetspencer
Thanks, I got it working.
Rod Jr.
Jan 28, 2019 11:16 AM
Gatordog
17
Oct 21, 2015 07:54 AM
High Binder
Nov 22, 2010 09:11 PM
jimwilsonmasonry
Jan 2, 2009 12:28 AM
Turf Truck
Feb 6, 2004 11:15 AM
