Cab removal
Old Feb 26, 2015 | 06:22 PM
travis e's Avatar
travis e
Cab removal
Any suggestions on lifting a crew cab on an 05 6.0 with out a shop lift? I'm going to replace the head gaskets and install studs. I have removed many regular cabs with a tractor front end loader and a 4x5 timber thru the windows. Wondering if any one has done the same to a crew cab? Any advice would be appreciated.
Old Feb 26, 2015 | 06:59 PM
cheezit's Avatar
cheezit
Ya do it cab on or pull the engine, both seem like safer options with out the correct tools.
It takes 4 hours to pull the heads cab on, it takes less then 4 hours to pullman engine.
Old Feb 26, 2015 | 08:37 PM
Per4mance's Avatar
Per4mance
X2 what Moe said.........pull the motor,your back will like you more
Old Feb 27, 2015 | 03:51 AM
Yahiko's Avatar
Yahiko
Just sitting here cringing with the description on how
you want to do this.
It's bad enough when your using the right tools. Leave the red neck
stuff to The Red Green show Red Green - The Official Red Green Web Site
I for one don't want to read about some guy getting squished by a 6.0L
We have a bad rep as it is.
Sean
Old Feb 27, 2015 | 07:39 AM
UGA33's Avatar
UGA33
I would pull the engine. It's not too bad. Doing headstuds in cab isn't terrible. But, after doing all three methods and a lift wasn't attainable, I would yank the engine.
Old Feb 27, 2015 | 10:07 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I can't remember which name he used, but under either "run6.0run" or "SuperDutyService", Anthony took two harbor freight engine stands and made one stand that grabs from the engine mounts instead of the rear. I'd fab that before ghetto-pulling the cab.
Old Feb 28, 2015 | 02:41 PM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
It works every day too.
Old Feb 28, 2015 | 03:19 PM
dannyboy950's Avatar
dannyboy950
Anthony your stand always reminded me of a detroit engine stand. A lot more clearance tho and more stable.
Old Feb 28, 2015 | 03:38 PM
Yahiko's Avatar
Yahiko
He got a much better price even after all the work he put into it.
Have a look at this bad boy
http://www.ebay.com/itm/OTC-1735B-2-000-lb-Capcity-Engine-Repair-Stand-/271569449558?hash=item3f3accf256&item=271569449558&pt=Motors_Automotive_Tools&vxp=mtrTalk about a price.
Sean
Old Feb 28, 2015 | 08:11 PM
dannyboy950
Otc has always been kind of proud of their tools.
Old Feb 28, 2015 | 09:53 PM
Yahiko's Avatar
Yahiko
You think.
This is about $15.00 worth of retail parts
http://www.ebay.com/itm/Ford-Rotunda-OTC-HP-Supply-Tube-Removal-Tool-303-1164-/371030402457?hash=item566322a599&item=371030402457&pt=Motors_Automotive_Tools&vxp=mtr
And Rotunda wants USD $219.45 for the same thing and I could not find the OTC one.
Sean
ClassicKidNick
Jun 7, 2021 11:31 PM
F357
Dec 23, 2014 08:16 AM
khakushia
Jan 22, 2012 07:16 AM
tjustice
Jul 12, 2011 07:56 AM
JimG1098
Large Truck
Jun 29, 2011 05:07 PM
