E303 cam help
Old Feb 16, 2015 | 12:20 AM
CCope94's Avatar
CCope94
E303 cam help
Im in need of some help, i have a 94 f150 4x4 with the 5.0 HO. I recently did a gt40p head swap as well as rebuilt the motor and installed an e303 cam. The truck starts and runs but has a few problems. It tachs about 4000 rpms on first start, but gradually drops to an idle. Does anything else need to be changed/adjusted? I am running the stock upper and lower intake. Any help would be much appreciated. Thanks
Old Feb 16, 2015 | 07:43 AM
ceetwarrior's Avatar
ceetwarrior
That's a pretty wild cam for a truck that shuts off at 4700rpm ... I think you're going to need it to be dyno tuned..
Old Feb 16, 2015 | 08:50 AM
rla2005's Avatar
rla2005
Did you convert to Mass Air-Flow (MAF)? That cam is not designed to work on Speed Density.
Old Feb 16, 2015 | 12:07 PM
CCope94's Avatar
CCope94
My truck is already mass airflow, it runs but something just isnt right about it. Almost like its getting to much fuel and not enough air
Old Feb 16, 2015 | 01:16 PM
rla2005's Avatar
rla2005
My apologies...I did not see you had a 1994 truck...doh!
Definitely need to check for air leaks after the MAF meter.
Midnite1987
Oct 7, 2017 11:25 PM
david00f150
Apr 18, 2006 05:03 PM
bob1987f
Dec 23, 2004 10:16 PM
tibbetts77
Sep 30, 2004 10:01 PM
MustangGT221
Nov 23, 2002 10:19 PM
