west coast mirrors
Old Feb 19, 2015 | 04:14 PM
greentruck72's Avatar
greentruck72
i have a set of westerns that are really long, but weren't there a shorter set, dunno the year of mine.
Old Feb 19, 2015 | 06:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes "West Coast JR's" are the same length bars top and bottom I do believe?
Old May 30, 2017 | 09:04 PM
Ruckin69's Avatar
Ruckin69
Resurrecting this thread for help
I am having clearance issues with my garage door with the type 8 mirrors. Are there any options with replacing them with a folding pair without drilling new holes? If I have to drill new holes which mirror will at least fit into some of the existing type 8 holes? Possibly Type 9's. Thanks
Old May 30, 2017 | 11:33 PM
1320stang's Avatar
1320stang
Have you tried spinning them 180* and flipping the mirror?
so that the mirror is on the "inside" not the outside?
BTW, 7's and 9's use the same holes.
Old May 31, 2017 | 06:31 AM
Ruckin69's Avatar
Ruckin69
Mirrors
Yes the mounting brackets stick out too far.
Old May 31, 2017 | 11:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Impossible!
There is one TYPE 7, 5 different TYPE 9's. At least 2 of the TYPE 9's have a different span (6 11/16" [D6TZ-12696-A] vs. 7 19/32" [D4TZ-17696-A]) between their upper/lower brackets.
Old May 31, 2017 | 12:02 PM
Ruckin69's Avatar
Ruckin69
Back to the question
What folding mirrors will be the best swap with the least amount of mofification? Thanks
Old May 31, 2017 | 12:41 PM
1320stang's Avatar
1320stang
POSSIBLE!!! Bill, you're usually right, but not always. I took the type 7's off my truck and replaced them with type 9's, they used the exact same holes. The 7's came on my truck from Ford. I didn't bend any brackets to install them.
Old May 31, 2017 | 01:24 PM
rougeriver's Avatar
rougeriver
Hello Ruckin, I have the same Type 8 mirrors on my truck, and I'm not a fan of them either. Each side mounts up using 5 bolts, and there doesn't seem to be any other mirrors that will utilize the existing holes...maybe Type 6 (never, ever seen this style) will use your three upper holes. You might get away with mounting a Type 9 so that one of the existing holes is used, but that is longshot, and big deal, because you still will have four other holes remaining.
I plan to mount some West Coast Jr's and just live with the other holes until I repaint my truck. These Type 2 mirrors are made to be adjustable, but I will have to check my pair to see if they just fold in or require a wrench to adjust.
Type 7 looks like it would require tools to fold it in, maybe someone with this style will chime in.
Type 9 sticks out quite a ways, but since it can be easily folded in, that is probably your best bet...and just learn to live with the extra holes.
David
Old May 31, 2017 | 02:00 PM
Ruckin69's Avatar
Ruckin69
Thank you
I know that I'm going to have those two holes on the bottom of the door but I'm hoping to utilize at least one of the two up top. These things are way too wide and I don't intend on painting the truck anytime soon. Yeah I was looking at the type 2 or 9's as well but I really hate to put more holes on an original painted door. Maybe I can get lucky and paint match them but I'm sure thats a longshot.
Old May 31, 2017 | 08:51 PM
Ruckin69's Avatar
Ruckin69
Ford Econoline Mirrors
I wonder if these would work? Type 6???
http://image.trucktrend.com/f/415175...-econoline.jpg
Old Jun 1, 2017 | 11:07 AM
NumberDummy
Info on TYPE 7 & TYPE 9 mirrors taken directly from the 1973/79 truck parts catalog.
Since most members of FTE have no parts catalog, I'm the messenger, typing what the parts catalogs say.
Since there are at least 3 different TYPE 9 mirrors that have a different span (6 11/32" - 7 13/32" - 7 19/32"). Which one of these mirrors would use the same mounting holes as a TYPE 7 mirror?
Plus, there are THREE different type TYPE 9's used 1978/79. None of these mirrors have their specs listed in the catalog.
1977f150xlt
13
Jul 18, 2009 04:29 AM
rolfe
Apr 27, 2009 11:36 PM
Ford Fx4
2009 - 2014 F150
13
Mar 13, 2008 01:03 PM
leeward
All Things Towing
Feb 1, 2007 07:17 AM
HJackson
Apr 5, 2006 06:51 AM
