Now just to figure out why the AMP Gauge doesn't work. Never has.
Amp gauge should have a yellow and red wire going to it. Red goes to the + side of the solenoid relay with a 4 amp fuse in line. Yellow also has a 4 amp inline fuse just before it gets spliced to a fatter black wire. That fat black wire runs from your alternator to the + side of the solenoid.
Hi
I have a BEAUTIFUL 1967 Ford F-250 Ranger Camper Special. Turquoise on White. Built 428 Cobra, Engle Cam, Hooker headers, Holly Equipt. Built C-6, Dana 60 Limited Slip . Air, Cruise..In near perfect shape. It's a hunting truck that runs real well.
the alternator gauge doesn't even move - even if I pull the connector out of the Voltage regulator
I replaced the cluster's voltage regulator to no avail
Any ideas?.
I guess I do not have permissions to post pictures.
Ford is a bit famous (over years) for providing amp gauges which move little or none irrespective of load and charging rate even though the charging system is working correctly. The only solution I have found is to replace the gauge. You can replace it with a Ford replacement part which will likely perform similarly. If you want some needle movement there is a fellow in Texas who can replace the gauge's movement with one that works. His work changes it to a voltmeter. You can retain the original face on the gauge, or he can provide an overlay which has a voltage scale. His work is good and reasonable in cost. I used his service a bit over a year ago and the gauge is still working well. The rebuilt gauge requires a little rewiring of the panel, but it is easy.
Rocketman's Classic Cougar Innovations
1010 Rice Street
P.O. Box 1589
Goldthwaite, TX 76844-1589 Rocketman's Classic Cougar Innovations rktmn@rccinnovations.com
phone: 512-541-2828
fax: 419-730-1608
