Sponsored by: Real Truck
2005 trans
Old Feb 14, 2015 | 07:09 PM
marxer2's Avatar
marxer2
2005 trans
what kind of fluid do I use in my 2005 F 350 transmission
Old Feb 15, 2015 | 08:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That depends on if it is a manual or an automatic transmission.
Old Feb 15, 2015 | 09:38 AM
marxer2's Avatar
marxer2
2005 f350 transfluid
owners manuel says mercon sp can't find anywhere autozone' o'rielley's don't show anything on mercon sp and owners manuel say's it won't mix with anyother fluids any help would be a great help.
Old Feb 15, 2015 | 09:45 AM
Ford_Doctor's Avatar
Ford_Doctor
Assuming this is for a Torqshift automatic, Motorcraft Mercon SP and Motorcraft Mercon LV. After the time your owner's manual was printed, both fluids are specified by Ford and can be mixed. (with each other) Couldn't tell you what the difference is between the two is other than price.
Old Feb 15, 2015 | 09:52 AM
jetjockey99's Avatar
jetjockey99
Mercon LV is the Ford replacement for Mercon SP in the Torgueshift trans. O'Reillys does show SP as still available in their stores on their web site. They also have LV available, they are interchangeable and will mix with each other. If you can't find Motorcraft brand, be very careful that the fluid you use states Mercon SP or LV compatible.
Old Feb 15, 2015 | 09:53 AM
marxer2's Avatar
marxer2
okay thanks I'll try to find motorcraft lv
Old Feb 15, 2015 | 10:07 AM
marxer2's Avatar
marxer2
thanks for the help
Old Feb 15, 2015 | 12:19 PM
Gage2502's Avatar
Gage2502
Well I wish Motorcraft would update their web site because it says not to mix the two.
take a look.
Product
Then check out their chart...
http://www.motorcraft.com/servlet/Bl...lob&blobkey=id
They make it complicated.
...Gage
Old Feb 18, 2015 | 06:45 PM
Ford_Doctor
Here is an early communication on this subject from 2009 which is what we call a Special Service Message or SSM. This jives with the application chart. I have been using LV in place of SP since then, replacing and mixing without any concerns. Looks like an error on the product description to me.
Originally Posted by Ford Motor Company
2976 - REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND 2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP. THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
Escapeartists
Escape & Escape Hybrid
Jan 6, 2015 11:24 AM
MauleOne
Feb 9, 2012 10:08 AM
Primetime1
Mar 4, 2009 06:47 PM
99F150
Oil & Lubrication
Oct 2, 2006 07:09 PM
homerunswing
Jul 4, 2006 02:26 PM
