4 Core Super Cooling Radiator
Old Feb 13, 2015 | 10:41 PM
1972RedNeck's Avatar
1972RedNeck
Does anybody know where to get a 4 core Super Cooling radiator? RockAuto used to have them (made by VistaPro I think) but no longer list them. NPD lists one but I ordered it and it turned out to only be a three core.
Ideas?
Old Feb 14, 2015 | 06:11 AM
gatorfor88's Avatar
gatorfor88
Maybe here?
Champion Cooling
Old Feb 14, 2015 | 07:59 AM
ronspolv's Avatar
ronspolv
US Radiator makes them.
Ford Truck, 1978-79 V8 351/460 Radiator
Old Feb 14, 2015 | 08:23 AM
1972RedNeck
Originally Posted by ronspolv
They make some darn nice radiators. I just don't have $833, $767, or even $633 to spend.
Does anyone have a vistapro part number?
Old Feb 14, 2015 | 10:23 AM
Bud Mud's Avatar
Bud Mud
if you go with Alum you wont need that many row's, also its lighter and dissipates heat much quicker, im replacing mine with this one when we start the resto in April.
1977 Ford F-250 ALL ALUMINUM RADIATOR 5.8L 8 351 | All Aluminum Radiator | Ford Parts
Old Feb 14, 2015 | 05:02 PM
1972RedNeck
So it will have the same cooling capacity even though it is 1/2" thinner?
Old Feb 14, 2015 | 06:02 PM
gatorfor88's Avatar
gatorfor88
I bought and installed a 3 core alum radiator in my old Bronco a couple of years ago.It runs consistently at 195 in the hot florida summer stop and go traffic.
Old Feb 14, 2015 | 06:16 PM
Tedster9's Avatar
Tedster9
Actually a copper/brass radiator is at least twice as efficient as an aluminum radiator. Different internal design makes them work OK.
Old Feb 14, 2015 | 07:37 PM
redneck_davis's Avatar
redneck_davis
I have a 3in thick solid alum rad I'm putting in mine this weekend .I'll let you know how it works out
Old Feb 14, 2015 | 08:50 PM
Tedster9's Avatar
Tedster9
I bought a Champion for the 64 a while back. Haven't installed it. Recently they blasted an email to customers asking for high res install photographs, of how things go and any fitment issues etc. Hm. Maybe I can send them a bill, too.
One thing I'm reading is that (supposedly) aluminum radiators are more susceptible to corrosion than brass, to the point that while tap water has been used forever as part of the glycol 50/50 mix, distilled or demineralized is required for use with aluminum. Champion has a warning label on the box stating as such.
Old Feb 15, 2015 | 01:53 AM
dustyroad's Avatar
dustyroad
To go along with what Tedster stated; get an anodize rod that screws into the drain plug. I believe the newer coolants (yellow/redS?) don't have that issue as much as the older green coolant. Someone will correct me though if I'm wrong.
Old Feb 15, 2015 | 03:29 AM
Tedster9's Avatar
Tedster9
Seemed to me, a new all aluminum radiator (in cast iron blocks like Fords) would want the newer type gold/platinum coolant or whatever they call it now. So I asked Champion about that. They said no, use the old green stuff. It's the engine that determines the coolant type from what I'm reading too.
Probably what I'll end up doing at radiator replacement time is find the block drains and do a real flush and drain of the system, and replace thermostat, flush heater core, maybe replace water pump etc.
Old Feb 15, 2015 | 09:33 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
My local radiator shop can get them, not sure of the brand, but I bought one from auto zone years ago and the radiator guy has fixed it a few times, he said those were really thin construction. I believe he is right. The ones he sells are the real deal and about $600 and heavier construction. If you buy one, watch the thickness. I poked a hole in mine changing the fan clutch by bumping the fan blade into the radiator. They are thin! I have tried a few of the other higher efficiency smaller radiators, they work all right, My thoughts are that the bigger camper special radiator is better just because it has a lot more capacity, more volume. Just my $0.02.
Old Feb 15, 2015 | 12:39 PM
1972RedNeck
Maybe I just need to bite the bullet and get a $600 or $700 radiator - I'm going to have to do some serious penny pinching.
Old Feb 15, 2015 | 02:00 PM
gatorfor88's Avatar
gatorfor88
Dont you have a radiator shop close by? They can re-core yours and even put new tanks on it if needed. Probably for a lot less than new.
89LX306
6.7L Power Stroke Diesel
Feb 26, 2015 10:09 AM
lee
May 15, 2014 06:03 PM
Dads79
Mar 7, 2007 01:28 PM
mmacsek
Jan 28, 2006 03:40 AM
Roamer
Nov 27, 2002 01:10 PM
