General Automotive Discussion
2014 Interseptor No power to fuel pump
Old Feb 12, 2015 | 07:22 PM
JWC 3's Avatar
JWC 3
I work at a small shop , in a small town . I work on some law enforcement vehicles . Just had a 2014 Interseptor sedan , 3.7 , AWD towed in . No fuel pressure , No power to the pump . Info is clear as mud ..... Any ideas ? FPM , ECM , ? Little info avalible on Mitchel or Identifix ... I do not want to ship it to the dealer { out of warranty } I have a code for open Ckt for the fuel pump system . Hectic at work , I do not remember the code . P0607 ? 670 ? ... Anyone see this ?
Old Feb 15, 2015 | 01:20 AM
Ford_Six's Avatar
Ford_Six
Check the relay, fuse, rollover switch (if they still use those) before you start going after the expensive stuff. Pop the relay out and jumper the input and output, if the pump runs then the relay is most likely bad.
Old Feb 15, 2015 | 01:56 AM
JWC 3's Avatar
JWC 3
Thanks! Got a wiring diagram . Found the fuel pump control module . It is bad . New one Monday . Only $42 my cost . A few issues with them . Just need better info than Mitchell provides .... I am using Identifix more and more ....
jemini
Jan 4, 2008 03:06 PM
bigwill250
13
Oct 28, 2006 09:44 PM
chris 2
Sep 11, 2006 08:03 PM
miks95
Jul 7, 2005 06:05 AM
bronco2va
Bronco II
Jan 15, 2004 12:14 PM
