Bronco II Ford Bronco II
fuel pump/fuel
Old Jan 8, 2004 | 01:44 PM
bronco2va's Avatar
bronco2va
fuel pump/fuel
I'm new here. excuse me if I do this wrong.
86 BII V6 4WD
I'm not getting fuel.
I cannot hear the pump running.
Replaced the fuel pump relay.
Testd all fusible links - good.
No power at inertia switch. Tried bypassing it anyway and no result.
I assume that no power at the inertia switch means no power to the pump either.
I do not have a schematic, so I don't know what else to test.
Old Jan 8, 2004 | 05:10 PM
mrshorty's Avatar
mrshorty
Another option might be the EEC relay -- it feeds power to the fuel pump relay.
I would strongly recommend you find a schematic. I don't know what others think, but I find it next to impossible to diagnose electrical problems without one. If you don't have a manual of your own, you can often find the information at a library. www.autozone.com has put the information from Chilton's on their website (look under repair info--vehicle repair guides). They aren't the best wiring diagrams, but it's a start.
Old Jan 8, 2004 | 09:09 PM
bronco2va's Avatar
bronco2va
Cool.
Advance can get me the EEC relay tomorrow morning.
I searhed some of the past posts on fuel.
An earlier post mentioned grounding the self test connector to run the fuel pump.
I did that and the fuel pump ran.
I was also able to start the truck with the terminal grounded.
I will be back on the road soon
Thanks!
Old Jan 8, 2004 | 10:16 PM
mrshorty's Avatar
mrshorty
that doesn't sound like a problem with the EEC relay. That sounds like a problem with the fuel pump control circuit. Maybe even the computer itself. I would suggest a proper wiring diagram and check the circuit though before replacing something as expensive as the computer.
Old Jan 9, 2004 | 10:50 AM
bronco2va's Avatar
bronco2va
You are correct. The new EEC relay did not start the truck. I'll try autozone.com for wiring diagrams. Thanks
Old Jan 9, 2004 | 12:22 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
I agree with mrshorty. I have some diagrams I can email to you, let me know if you need them.
Old Jan 9, 2004 | 12:49 PM
bronco2va's Avatar
bronco2va
This is a great site. I appreciate all the info.
Yes I would like the wiring diagrams.
I also need help finding the EEC components.
I just got the truck this year, but this is the first time I have had to do any real repairs on it.
I'm taking a crash course on Broncos to try to get it going again!
Old Jan 14, 2004 | 11:26 PM
bronco2va's Avatar
bronco2va
The truck is running again!
I replaced the EEC-IV
That sounds simple enough but I had no idea how hard it is to find the right one around here.
Its a F2A, according to the label.
Ford dealer said: part no longer listed
NAPA said: Its a califoria model - meaning - your out of luck
The only place that could get it was A&B Auto
I got a Ford rebuilt (with GTE ID number) multi-fit unit. Runs great.
Long story short - replaced computer,
got fuel!
Old Jan 15, 2004 | 11:37 AM
mrshorty's Avatar
mrshorty
I have another issue on another vehicle that I'm trying to decide if the problem is the computer or not. How did you determine that the computer was bad before replacing it? Or did you replace the computer in the hopes that it would fix the problem?
Old Jan 15, 2004 | 12:14 PM
bronco2va's Avatar
bronco2va
It was really just a shot in the dark.
I was unable to get the self test running.
I had a new fuel relay and EEC relay.
I still had spark, so I thought the computer was good but did not know what else to do.
Sometimes the shot in the dark is right. I wish I could have diagnosed it instead of guessing (a $145 guess) but it runs now!
MI Yeti
Jul 20, 2014 11:33 AM
phat rat
19
Sep 13, 2009 10:00 PM
geckocub69
1997 - 2003 F150
Jul 1, 2007 04:46 PM
emboyd
Aug 27, 2003 08:53 AM
