License Plate lights.
Old Feb 12, 2015 | 04:30 PM
Justin Doe's Avatar
Justin Doe
INFO
-Replacing with Optronics LP11CS - License Plate/Utility Light | O'Reilly Auto Parts
-Brown Wire is spliced to make three wires.
-Brown wire has power
-Lights do not light up
Questions
-1.Do the lights ground to the bumper?
if not
-2.Can I ground the brown wire to the Bumper or somewhere with a small screw?
-3.Where Should I check for grounding of rear lighting?
Sorry, topic has been covered so many times. I couldn't find any thing conclusive.
Old Feb 12, 2015 | 04:48 PM
Justin Doe's Avatar
Justin Doe
Here is the Brown Power wire. It splits into three wires here. Two are shorter and one runs up to the passenger side Tail light
Old Feb 12, 2015 | 06:10 PM
Franklin2's Avatar
Franklin2
The brown wire is the hot wire for the lights. Ground it and you will blow the fuse.
How many wires does the light in the link have? If it has one, tie the brown wire to it, the light grounds through the bumper. If it has two, put one of the wires to the brown wire and bolt the other wire to a good ground somewhere.
Old Feb 12, 2015 | 06:13 PM
Justin Doe's Avatar
Justin Doe
It has one.
Do you think I should try a wire brush to clean up the hole in the bumper?
Old Feb 12, 2015 | 06:15 PM
Franklin2's Avatar
Franklin2
It's going to be the bulb to the bumper, or the bumper to the frame, or the frame to the battery negative. It must be losing it somewhere. Get a short piece of wire and start jumping across metal pieces to see what you get. Like touching the bumper to the edge of the light, touching the bumper to the frame, etc.
Old Feb 12, 2015 | 06:18 PM
Justin Doe's Avatar
Justin Doe
hmmm okay.
Do you know where is the factory ground located?
Old Feb 12, 2015 | 06:21 PM
Franklin2's Avatar
Franklin2
Not sure the license plate lights had a factory ground did they? I want to say the taillight grounds are up behind the housings in the bed. And there may be a ground wire bolted to the frame over on the driver's side rear of the frame rail/crossmember.
Old Feb 12, 2015 | 09:24 PM
ctubutis's Avatar
ctubutis
IIRC its ground is behind the LH tail light assembly (but Ford used at least two specific locations behind the assembly for that ground over the years, and I don't remember what they are or when they changed).
Old Feb 13, 2015 | 05:25 PM
Justin Doe's Avatar
Justin Doe
These Three wires come out of the harness from that direction.
They don't have any power. I will reverse the test light and see if they are grounded Sunday. If they are should I screw them to the bumper? Thannks for the help guys!
Old Feb 13, 2015 | 07:33 PM
ctubutis's Avatar
ctubutis
All the blacks are ground wires, and one of those from that bundle will get screwed to the truck's body someplace (which IIRC happens behind the LH tail light assembly someplace).
The colored wires will be powered at different times...
- Orange/light-blue = RH stop & turn/emergency signal lamp
- Black/Pink = Back-up lamp
- Brown = Side marker/parking lamps/running lamps/license plate illumination
Old Feb 19, 2015 | 08:11 PM
Justin Doe's Avatar
Justin Doe
Cool. So this turned out to be pretty simple for me. I tested the bumper for ground. It had ground. So I proceeded to file the holes where the light assembly goes. Wire brushed it for whatever reason and voila. There was some gross looking build up that wasn't allowing the lights to ground.
Old Feb 20, 2015 | 06:50 AM
1986F150six's Avatar
1986F150six
Justin Doe,
Glad to hear you were successful. You might want to "rep" Franklin2 and ctubutis. They went "beyond the call" with regard to assisting you! Both have much knowledge and are willing to help.
FERacing66
May 15, 2006 05:46 AM
bigexpo
Electrical Systems/Wiring
Aug 9, 2005 11:13 PM
kylekip68
Oct 27, 2004 07:52 AM
bubbin
Jan 24, 2004 05:49 PM
slorch
Mar 12, 2003 01:06 PM
