Single wire replacing 2-wire???
Old Mar 12, 2003 | 11:53 AM
slorch's Avatar
slorch
Question Single wire replacing 2-wire???
I replaced my bashed step bumper with one from Fey last weekend. The new bumper came with license plate lights that are single-wire.
The originals (93 F-150) have 2 wires to the socket. Unfortunately, the old sockets do not fit the holes in the new bumper.
Is there an easy way for me to power the new lights off the 2-wire originals?? Tapping into either of the originals does nothing, I assume since there is no ground/circuit completion.
Old Mar 12, 2003 | 11:59 AM
delliscoracing's Avatar
delliscoracing
one wire should be a ground and the other a hot wire.
You may have to play around with them ground one to the new
socket and attach the other to the wire should work make sure
that you dont have a blown fuse good luck
Old Mar 12, 2003 | 01:06 PM
Franklin2's Avatar
Franklin2
Be careful grounding those wires because one of them has 12 volts on it when the lights are on, and you will blow a fuse. I don't know about your year truck, but most of the Fords had a brown wire as the hot wire for the bulbs. The easiest way is to buy a test light at the store. Hook one end of the test light to ground, turn the headlamp switch on, and touch the probe to each wire. The one that lights the test light will be the one you hook to your new lights.
The only reason the original sockets had two wires is because they where plastic.
texag1989
Apr 4, 2017 11:43 AM
oft
Jul 11, 2016 06:20 AM
4x4man514
Apr 14, 2016 03:55 AM
robfattig88
Apr 13, 2016 10:47 AM
lcgeek
Oct 16, 2015 05:37 PM
