Cranky
Old Feb 15, 2015 | 08:30 PM
  #46
Backdraft-14's Avatar
Backdraft-14
The potential issue I see would be the drain tube is only connected to the drain valve by a non-clamped pushed on fuel line. Depending on the pressure coming out it could potential blow it off and fill the valley with diesel.
Robert
Old Feb 15, 2015 | 08:54 PM
  #47
ZombiePopper's Avatar
ZombiePopper
Damn,
Didn't consider that...
Old Feb 15, 2015 | 09:14 PM
  #48
petrokiller's Avatar
petrokiller
I think I paid around $140 after coupon. I forgot to mention you need to purchase the scan gauge 2 online and use the code for the 30 percent off.. Then go to the store and pick it up.
  #49
ZombiePopper
Ok next question,
What's required to rebuild a draîn valve?
Just o-rings?
I have a large box of assorted o-rings (for various tractor repairs)...
Old Feb 16, 2015 | 12:34 AM
  #50
Backdraft-14
The o-ring size are 1/2" od, 1/4" id, 1/8" material, "Courtesy of Springer Pop"
As for install this is a great reference:
Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page Just make sure they are fuel rated o-rings
Robert
Old Feb 16, 2015 | 06:55 AM
  #51
Tugly's Avatar
Tugly
I've used this kit on two separate trucks without issue: [LINK]
Old Feb 18, 2015 | 12:31 PM
  #52
ZombiePopper
Great links and info guys it's exactly what I needed thanks.
Why are there so many options on o-ring material though and what works best for the drain valve/fuel bowl?
Old Feb 20, 2015 | 08:12 AM
  #53
Tugly's Avatar
Tugly
I used to know this. I want to say one works with biodiesel, and the other... not so much. There should be documentation on riffraffdiesel.com to explain the differences. If not, call 'em up. Clay is one of the parts gurus here.
Old Feb 20, 2015 | 03:03 PM
  #54
HKusp's Avatar
HKusp
I think Viton is the best for regular diesel if I remember correctly.
LCA078
Dec 11, 2013 06:23 AM
hfdbuck09
Jan 8, 2011 07:35 PM
GatorBait1996
Dec 22, 2010 08:02 PM
1957F100
Oct 3, 2009 08:24 AM
RocketScience
39
Jun 1, 2005 09:08 PM
