Cranky
Old Feb 13, 2015 | 04:58 PM
  #31
ZombiePopper's Avatar
ZombiePopper
Could a leak cause any issues
Besides the obvious
Old Feb 13, 2015 | 05:09 PM
  #32
Backdraft-14's Avatar
Backdraft-14
The flash point of diesel is 126° F with an auto ignition temp of 493° F. Much cheaper to fix a fuel leak in my opinion.
Robert
Old Feb 13, 2015 | 06:21 PM
  #33
CampSpringsJohn's Avatar
CampSpringsJohn
Originally Posted by thomabb
A short 1 second grunt noise shortly after key-on is the antilock brake system self test, but that is on the driver's side.
After all these years of owning my truck, I now know what that damn noise is! Thanks!
Old Feb 13, 2015 | 06:46 PM
  #34
ZombiePopper
I agree 100% I didn't mean to imply I was going to let it go, I was just wondering if it could suck air if it was leaking?
Or if it would run rough? etc etc
I appreciate the assistance and information guys.
Old Feb 13, 2015 | 06:57 PM
  #35
AllaboutMPG's Avatar
AllaboutMPG
James,
The fuel bowl valve leak is a super common issue on our trucks. It will not cause anything more than a wet spot and diesel smell in the cab. The fix is easy, lots of you tube videos about it and parts are cheap.
Fluorosilicone Drain Valve Orings Set - Riffraff Diesel Performance
Complete Fuel Bowl Seal Kit 99-03 - Riffraff Diesel Performance
Old Feb 13, 2015 | 07:18 PM
  #36
ZombiePopper
Great really appreciate the links!
Looks like that now on the top of my list
Old Feb 14, 2015 | 10:14 AM
  #37
ZombiePopper
Ok I took my multimeter out and did some checking,
I tested the relay on top of the engine and I'm confused by my readings, could someone tell me if the limits are correct or bad?
Pass batt. 12.97 off and 14.46 run
Dr batt 12.97 off and 14.50 run
Constant? Passenger side big lug 12.92 off and 14.56 run
Big lug drivers side -.001-.002? Off and key on (not running) -.005? Running -.100 (fluctuates slightly off and key on)
frt small lug 14.33 running
back small lug 14.35 running
The thing that confuses me is the key off and on, drivers side big lug, readings
I can hear and feel the relay click on when I turn the key to on (not running)
Old Feb 14, 2015 | 10:25 AM
  #38
Tugly's Avatar
Tugly
Your alternator is charging about 14.5 volts, this is good. As for the GP lug on the relay, it won't read diddly on a warm truck that's running. It only goes high when you first turn the key (up to 2 minutes max on an Alaskan morning), and the warmer it is, the shorter it stays on - down to just a few seconds.
The ultimate Glow Plug Relay test: One probe on each lug. 12 Volts when relay is off - zero volts when relay is on. These numbers are approximate, so don't worry about two decimal places.
Old Feb 14, 2015 | 10:34 AM
  #39
ZombiePopper
This is the relay I tested, did I accidentally test the intake heater relay?
So with the key off I should put 1 probe on each big lug and I should have 12v correct?
Ok I'm getting
12.94 v between the 2 large lugs key off
Old Feb 14, 2015 | 11:39 AM
  #40
Tugly's Avatar
Tugly
You have an E99, which has no IAH. You are testing the correct relay.
Old Feb 14, 2015 | 01:30 PM
  #41
thomabb's Avatar
thomabb
12.94v across the two big lugs with key off is relay off - battery voltage. With the truck cold, measure the voltage across the lugs and watch while someone turns the key to on. That will be the voltage drop across the relay.
Old Feb 14, 2015 | 01:31 PM
  #42
petrokiller's Avatar
petrokiller
James the closest lug to the passenger side should read 12V even with the key in your pocket. LOL
It has constant power. If its cold enough the pcm says have GPR lets heat this baby up. And then clicks just sending that constant 12V to all the GP's if they all work.
The LED mod that was mentioned is like $10 with wire and led at Radio Shack. This tells you that your GPR is energizing those GP's.
I have the mod and almost any cold start even in the 40's my GPR is energized for 2 minutes. Even on for 1st start in the summer. You can also watch your dash volt guage for the drop and rise.
Here ya go
https://www.ford-trucks.com/forums/7...wmriceman.html
Old Feb 14, 2015 | 06:06 PM
  #43
ZombiePopper
Thanks petrokiller I'll def check it out,
Yes I'm getting 12v on the pass side big lug with no key and key off and get more than 12v while running.
Old Feb 15, 2015 | 06:01 PM
  #44
petrokiller
Here is my F250 with High idle warm up going. Outside was 18 dg. My EOT was at 38.5 when I started my truck probably 7 mins earlier and it went up about 50 dg.
That's a scanguage II that I view my sensors with. I like it a lot for the money. Search 30% off coupon code for Advanced Auto and get it pretty cheap.
Old Feb 15, 2015 | 08:07 PM
  #45
ZombiePopper
Thanks Brad, I really like that scan tool, I'm going to have to look that up, how much was it if you don't mind me asking(?). Here in KS we were down to single digit (4 degrees w/windchill) and my high idle jumped up to about 1000 rpm's with the temps.
I'm sure you guys are sick of my questions but I want to verify that what I did today is "ok" or a "no-go".
Since my drain valve is leaking off and on, I want to get a fuel bowl rebuild kit, a new drain valve and a drain valve rebuild kit (so I can rebuild my old drain valve and just swap them out as needed (spares are good).
But here in KS we're fixing to get hit with some snow and MOnday is a holiday, so if I ordered these parts I probably wouldn't get them till middle of the week (best case) or the end of the week.
So given that my super duty is my driver AND the snow coming tonite I really need my truck.
Here's what I did (.temporary only until I get the replacement parts);
I grabbed a length (15" or so) of fuel injection hose, and I clamped an end of it to my drain valve tube. On the other end I clamped a plug to stop any diesel from dripping out.
It's not ideal and it's not the proper way, but gets my truck back into operational status.
Is this okay?
Can it cause a problem/damage?
