These are the non-towing mirrors. The truck was pretty well used when I got it; one tow mirror was broken, the glass in the other wouldn't move when I used the switch.
I found a set of power non-towing mirror locally and installed them. They dont work. I tested the switch and the wires at the connectors and I am getting 12v to the mirrors.
So I was thinking maybe it was a ground problem???? Then I took a 12v test light and probed the mirror wires at the connector (clip connected to ground) and then the mirrors slowly moved. I remove the test light and they don't work. Now I am confused.
