timing light
Old Feb 10, 2015 | 09:47 PM
1990-f250's Avatar
1990-f250
timing light
Hey guys I borrowed a snap on timing light from my uncle and it's a mt241a. Anyways, my question is it has a dial on the back for timing advance, but how do I use it? I'm used to the simple ones where you just point and turn the distributer.
Old Feb 11, 2015 | 06:13 AM
dixie460's Avatar
dixie460
You take and set that dial to your desired timing and when you shine the light at the timing pointer it will show ZERO degrees when the timing is at the setting you dialed in. So if you want 12 degrees advance, set the dial to 12 degrees then turn the distributor til the timing pointer shows zero.
You can also just set the dial to zero to start with and use it as a simple timing light like you're used to. It's just a nice feature to have if for instance your balancer doesn't have a mark at exactly 12 degrees or whatever.
Old Feb 11, 2015 | 08:50 AM
1990-f250's Avatar
1990-f250
Oh alright thanks
riverguideguy
13
Apr 14, 2013 01:12 PM
turnkyle
Aug 12, 2012 08:44 AM
ramarado
Feb 23, 2008 08:18 PM
Gr8ride
Jan 28, 2008 06:23 PM
a500ponies
Feb 18, 2004 09:52 AM
