Adding Drain Plug 4R70W
Old Feb 10, 2015 | 01:56 AM
TexasGuy001's Avatar
TexasGuy001
Question Adding Drain Plug 4R70W
I am planning on adding this Dorman transmission drain plug to my truck's 4R70W the next time it gets serviced. Is there a preferred location to make the hole in the pan?
http://www.summitracing.com/parts/rn...FUE0aQodiyQAqQ
Old Feb 10, 2015 | 02:56 AM
Diesel_Brad's Avatar
Diesel_Brad
I can't help you on location,,,,,
but I recommend NOT using that drain plug.
get yourself a factory engine oil drain plug, then get a nut that fits it.
Drill the hole where it needs to be, put drain plug thru hole and hand tighten nut.
Then tack weld the nut to the inside of the pan.
Remove drain plug and completely weld nut to the inside of the pan.
How you have a REAL hole to drain the oil and the nut will NEVER spin or leak
Old Feb 10, 2015 | 05:22 AM
dixie460's Avatar
dixie460
What he said. Don't mess with that type of plug, get a real one and if you don't have a welder then a weld shop will do the job for a few bucks.
Old Feb 11, 2015 | 02:20 AM
TexasGuy001
I already have this one. What's really wrong with it? I know people that have used this kit with no issues. Does anyone have a recommendation on what plug to get or where to get it from? I have not really found anything else when searching. Several other companies offer the same style kit as this Dorman one.
Old Feb 11, 2015 | 04:12 AM
Diesel_Brad
They leak, they come loose, and they take FORVER to drain
Old Feb 11, 2015 | 11:21 AM
Conanski's Avatar
Conanski
I have that Summit drain plug in my AOD pan... it has never leaked. I installed the plug in the little dimple on the bottom of the pan.
Old Feb 11, 2015 | 01:33 PM
wag53's Avatar
wag53
Used the Dorman one in my e40d at low dimple. I cheated and used red Locktite on it and tightened the devil out of it. No leak 3 yrs.
Old Feb 11, 2015 | 05:52 PM
TexasGuy001
If its good enough for Conanski, its good enough for me. I'm not really concerned with the length of time require for draining, just want to avoid the mess.
I think the 4wd pan has a low dimple, but the 2wd pan doesn't. I guess I'll have to look and see where a suitable spot will be.
Old Feb 11, 2015 | 08:03 PM
1993_f350_2013's Avatar
1993_f350_2013
they''re steel pans right? if so could a fella just drill a hole and weld a nut on the outside and use a bolt with a copper washer on the end of it? i watched an episode of "trucks" on the speed channel and he did that to a rear diff cover on a jeep Cherokee.
Old Feb 11, 2015 | 11:24 PM
Tim Hodgson's Avatar
Tim Hodgson
You guys must be great welders (but then I am really only am a grinder trying to become a welder). Because welding a thin pan to a thick bung drain plug didn't work for me.
First, the thin pan is easy to blow holes in when you are trying to heat the thick bung to fuse the metal with the thin pan.
Second, no matter how hard I tried to clean the used transmission pan (with acetone, etc.) I couldn't seem to get all the oil out of the pores of the metal. Then while welding, the metal would gas off causing porosity in my weld which leaked ATF. I must have taken that pan off and re-welded it three times to try to fix ATF seepage before finally blowing a hole so big in it that I gave up and bought an F Series 4x4 deep pan & filter for my E Series 2wd 4R100.
So, if any of youse guys have actually successfully done this, please educate me as to how you did it.
Old Feb 12, 2015 | 12:58 AM
MR KROGOTH's Avatar
MR KROGOTH
-snipped-
Are you using a flux-core wire welder or gas shield welder?
I wouldnt try it with a flux core, but I wouldnt think twice with a gas 110v welder. I'd torch the area first to burn out the ATF in the pores, then do a tiny tack to hold it in place. Then burn it hot in one pass, holding the heat on the bung, not the pan. Did the same thing with a gas tank. I think I have pictures of how I did that somewhere.
jaybe
Jun 24, 2007 07:54 PM
clintbonnie
Aug 8, 2005 02:38 PM
98 4.6 locked up
1997 - 2003 F150
Mar 18, 2004 01:44 AM
Paul24
Aug 18, 2003 08:11 AM
HD
Oil & Lubrication
16
Jun 11, 2003 05:49 AM
