Electronic Ignition Problems - Help!
Old Feb 9, 2015 | 02:45 PM
kpromano's Avatar
kpromano
Hello,
I have a 1983 F100 with a 302 and automatic transmission. Previous owner installed an electronic ignition. The problem I am having is that I am getting backfires and really no power. Mostly happens right after I start the truck. I think the backfire and no power is because the electronic ignition has a problem. I can get the truck to run fine if I shut it off, coast, and then re-start it.
I pulled the distributor cap and cleaned it. The only other thing that looks different is that the coil appears to be stock.
Any help would be greatly appreciated.
Thanks
Kevin
Old Feb 9, 2015 | 06:03 PM
maytag906's Avatar
maytag906
What brand of ignition?
Old Feb 9, 2015 | 06:42 PM
kpromano's Avatar
kpromano
Brand
I am having trouble figuring out the make of the system. When I pulled the distributor cap I saw what is a round series of magnets. The other thing is that the base (right below the cap) has a square part that bulges out. I don't think it is a Petronix or MSD.
Old Feb 10, 2015 | 08:39 AM
Wagonboy's Avatar
Wagonboy
Pictures would help !
Old Feb 10, 2015 | 10:52 AM
LARIAT 85's Avatar
LARIAT 85
Your description sounds like you have the later-model stock TFI ignition, where the ignition module is bolted to the side of the distributor.
Does your distributor have a vacuum advance canister with a vacuum hose connected to it?
Old Feb 10, 2015 | 02:41 PM
kpromano's Avatar
kpromano
Vacuum Advance
Yes, the distributor has a vacuum advance. Photos coming.
Old Feb 10, 2015 | 04:34 PM
kpromano's Avatar
kpromano
Hello, I have photos but can't post for some reason. If you would be willing to look at the photos and possibly help me I would really appreciate it. Send me an email at kpromano105@gmail.com
Thanks
Sportsterengr
17
Apr 7, 2016 09:08 PM
bamaf150
16
Apr 30, 2010 11:56 AM
dgassett
19
Mar 17, 2007 11:04 PM
seawulff
17
Nov 9, 2006 02:51 PM
BigBlueBeast
17
Sep 18, 2003 06:39 PM
