PerTronix Ignition
Old Nov 6, 2006 | 03:18 PM
seawulff's Avatar
seawulff
PerTronix Ignition
Has anyone changed out the points/condenser for the PerTronix electrical ignition system that fits under the stock distributor. How does it work for you?
Chris
Old Nov 6, 2006 | 03:56 PM
packrat56's Avatar
packrat56
I did it in my 56', it has a 302 from 1971. It is GREAT... GREAT... GREAT... Just my opinion..... But, its GREAT...
Old Nov 6, 2006 | 04:25 PM
seawulff's Avatar
seawulff
Try to control how you really feel! I am thinking of putting it in my stock '57 312.
Old Nov 6, 2006 | 08:26 PM
doug51f1's Avatar
doug51f1
My 289 is running on the Pertronix. It is probably the best thing you could ever do for a breaker point ignition system. My engine starts and runs much more smoothly with it than it ever did with the points. I'm with PackRat on this one!
Old Nov 6, 2006 | 08:34 PM
havi's Avatar
havi
I'll have the Roast Duck
At work, we even used one on our 1950's Hyster forklift!!! I'm sold on them.
Old Nov 6, 2006 | 08:41 PM
ferguson777's Avatar
ferguson777
Neighbour and I did his 66 Galaxie. Starts quicker and runs smoother and was incredibly easy to install.
Old Nov 6, 2006 | 08:54 PM
imlowr2's Avatar
imlowr2
I'm running one on my original 66 Mustang and my 56 truck. The truck had a Mallory dual point distributor in it. After paying megabucks and burning up two sets of points, I put the Pertronix unit in and it runs great. No more points and still looks like a high performance distributor. (Don't tell anyone!)
Old Nov 7, 2006 | 11:50 AM
sgtrwg's Avatar
sgtrwg
I've been thinking about doing the same thing on flat head. I seem to recall a thread either on here or the ford flat head site that there had been some problems running it if you retained the generator rather than updating to an alternator.
Here is the link to the info: http://www.btc-bci.com/~billben/flathead.htm
it's not real current and hopfully they have resolved the problems.
Old Nov 7, 2006 | 01:50 PM
JoeSwing78's Avatar
JoeSwing78
Smile
Swapping in a Pertonix and loosing the points was one of the first things I did on my truck. Starts much easier, no lagging, and just overall run's more smooth. You won't regret it!
Old Nov 7, 2006 | 04:59 PM
DT56's Avatar
DT56
When my points went bad with my 390 in my 56, I put in a Pertronix and have never looked back!!
Old Nov 7, 2006 | 06:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As I believe the referenced thread states, the spike when a generator regulator opens/closes was causing real problems, mostly on the 6v models.
I'm leery of the Pertronix just because it isn't as rugged as the typical OEM GM/Ford/MoPar electronics. They use a toothed wheel on most OEM, no light beams, and "reading" the stock points-type dizzy cam seems like a major source of inaccuracy. That said, lots of people love them....
Old Nov 8, 2006 | 10:33 AM
Jag Red 54's Avatar
Jag Red 54
I've had one on the truck for 2 years and on the 55
fairlane 6-volt system for 6 years. No problems and easy installation. I've never heard anybody compalin about pertronix. Jag
Old Nov 8, 2006 | 02:49 PM
mikeiz's Avatar
mikeiz
installed a pentronix 2 in my 66 mustang car would not start . sent it back and received a new unit car still would not start . sent it back and installed pentronix 1 , car runs great. always used pertronix coils. would really like to install a pertronix in my 54 f100 6 volt w/generator & pos ground.i am afraid to because truck runs great just do not like changing points. i have read a lot of pros & cons about 6 volt pertronix. mike
Old Nov 8, 2006 | 05:46 PM
56f600's Avatar
56f600
I know from experience that the 12 volt pertronix set ups like a full 12 volts, preferably more. Make sure your charging system is up to snuff and you will have no problems.
Old Nov 8, 2006 | 11:50 PM
HT32BSX115's Avatar
HT32BSX115
I put one in my 55 F-600 and it ran great until the timing set slipped!
I had to move the dist about 20 degrees to get it to run after that.......so I kept the Pertronix distributor and replaced the engine!
I have a 292 now that the same distributor is going on.
Regards,
Rick
