Brake Fluid And Bleeding Procedure?
Old Feb 8, 2015 | 12:43 PM
TKegs763's Avatar
TKegs763
Curious as to what type and brand of brake fluid that our trucks prefer? What is the proper bleeding procedure. I put new pads, new calipers (not remans), and rotors all the way around, about a year and a half ago. Noticed a grinding sound coming from the rear and this is what I found this morning. By the looks of it, it's been grinding for quite some time.
https://www.ford-trucks.com/forums/a...1&d=1423421330
Old Feb 8, 2015 | 12:46 PM
FiznUKa's Avatar
FiznUKa
Photo link no good
Old Feb 8, 2015 | 12:51 PM
TKegs763's Avatar
TKegs763
Originally Posted by FiznUKa
Photo link no good
Fixed it, and the brake pad is completely ground down to the metal.
SpringerPop's Avatar
SpringerPop
A good-quality DOT-3/4 fluid. Get at least a couple of quarts to ensure you can do the job thoroughly.
DOT-5 is NOT recommended!
I personally don't see the need for "Speed Bleeders".
Start with the caliper farthest from the master cylinder, and progress in toward the closest. Get an assistant to pump the brakes for you.
There are other methods that are just as effective as manually "pumping", especially if you have a vacuun pump around.
YouTube videos all over the place for the specific procedures.
Pop
Old Feb 8, 2015 | 12:52 PM
TKegs763's Avatar
TKegs763
I figured it was a stuck slide pin, but they were free. Has to be a bad caliper, is what I'm thinking.
Old Feb 8, 2015 | 01:49 PM
petrokiller's Avatar
petrokiller
If bought parts local see if they will make good on repair replacements.
If slide pin is free it's prob a bad piston on caliper.
Old Feb 8, 2015 | 02:01 PM
AllaboutMPG's Avatar
AllaboutMPG
Pop
I never seem to have an assistant around when I get ready to work on my vehicles so I have speed bleeders and like them alot.
Old Feb 8, 2015 | 02:37 PM
cj45lc's Avatar
cj45lc
assistant what is that LOL
that's why I use the gravity method, takes a little longer but gets the job done
Old Feb 8, 2015 | 03:20 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Speed Bleeders are EXCELLENT! We got them on everything. We use that little IV bag with hose, over and over again.
Old Feb 8, 2015 | 04:31 PM
SpringerPop
Remember, I didn't say Speed Bleeders weren't any good, I just said I don't personally see the need for them.
I have a top-of-the-line vacuum pump, too, and I don't use that, either.
Guess I'm just "old school" here.
As always, YMMV.
Pop
joegeds
Mar 10, 2016 04:52 AM
bigk_54
Dec 22, 2009 08:27 PM
okwaho1650
Oct 8, 2008 05:13 PM
BiodieselPanther
1983 - 2012 Ranger & B-Series
Jan 13, 2006 09:12 PM
kc5deb
1997 - 2003 F150
Oct 14, 2004 11:42 AM
