2011 spark plug replacement
Old Feb 7, 2015 | 07:45 PM
bdlesch's Avatar
bdlesch
This is Just an FYI. I replaced the plugs in my 2011 F-150 3.5 Ecoboostwith 50,000 miles. I had a miss under heavy acceleration. Turns out the plugs had a gap over .090" and the side electrode was burned. Replaced them and all is well. Hope this might help someone .
Thanks!
Old Feb 7, 2015 | 08:00 PM
j_schmidt's Avatar
j_schmidt
Do the 11s have coil on plugs like the late 90s model?
Izzy351's Avatar
Izzy351
Did you put the Motorcraft SP 534 plugs in or stay with stock? I just learned that the stock plugs wear faster and are known to have a lot of gap variance. I'll be monitoring this.
Old Feb 7, 2015 | 08:01 PM
Izzy351's Avatar
Izzy351
Yes, the EcoBoost is COP.
Old Feb 7, 2015 | 08:35 PM
bdlesch's Avatar
bdlesch
Yes ,they are the The Motorcraft SP 534. I purchsed them from Stage 3 Motorsports. They came gapped at .030", I checked each one to make sure. The drivers side was a bit tricky, but nothing to bad. I have a Hypertech tuner and a 3" Flowmaster cat-back. I know others make more power.but I am counting on reliability. I am impressed with the performance and towing. I tow a heavy boat (7000 lbs.) and have no problems. I have been getting 18-19 mpg in mixed driving. I will see if the plugs helped that any.
Old Feb 7, 2015 | 08:38 PM
bdlesch's Avatar
bdlesch
Yes j schmidt, they have the coil on plug.
Old Feb 7, 2015 | 08:40 PM
j_schmidt's Avatar
j_schmidt
Are they as a big of a pain to change as the used to be. My 98 was like a 4 hour job i HATED it lol
Old Feb 7, 2015 | 08:49 PM
bdlesch's Avatar
bdlesch
Actually it was pretty easy. It took about an hour or so. I needed a step stool to reach them. The drivers side it a little tougher, but not bad I thought. The wire to the fuel regulator has the be pulled to remove the back plug and the pcv is in the way for the front plug. Other than those two issues, a straight forward job. I did apply anti-seize on the threads for insurance.
Old Feb 7, 2015 | 09:37 PM
j_schmidt's Avatar
j_schmidt
Ok that doesnt seem as bad. Hell i had to un bolt the Fuel rail on the driver side. Freaking nightmare. Electrode grease is a MUST with COPs slightest bit of moisture and they will short out.just fyi
wkbrdtx
17
Jul 14, 2013 02:00 AM
markfh11q
1983 - 2012 Ranger & B-Series
Aug 13, 2007 07:46 PM
aspellicy
2004 - 2008 F150
Mar 1, 2007 03:58 AM
4.9inline6
23
Oct 25, 2005 11:07 PM
holland501
3.0L V6
Sep 14, 2005 11:27 PM
