revs up
Old Feb 7, 2015 | 01:53 PM
bcamill's Avatar
bcamill
revs up
I have a 1983 F150 flareside that is just about done from a full restoration. I started the engine for the first time today and the RPM's went right up to the max. I had to shut it down quick. The carb is new and supposedly bench tested. the throttle does return to idle. I check the vacuum lines (new) and all seem to be connected. Could it be a leak in the manifold? What should I check next?
Old Feb 7, 2015 | 05:25 PM
Franklin2's Avatar
Franklin2
What carb do you have?
Old Feb 7, 2015 | 09:53 PM
80ford100's Avatar
80ford100
I had the same thing happen to me the other night. I was working fast because I had to get my truck back up and running for school the next morning. In my hurry, I failed to notice that the Holley carb I installed had a throttle that pulled in the oposite direction as the edlebrock that was on it. The throttle cable when the pedal wasnt depressed was actually holfing it at WOT and when you stepped on it it idled down. Kinda like one of those international loaders. Took me 2 hours of frustration to figure this out.
Old Feb 8, 2015 | 10:07 AM
bcamill's Avatar
bcamill
Motorcraft 2150. Exact replacement. Would timing do this?
Old Feb 8, 2015 | 10:26 AM
ctubutis's Avatar
ctubutis
No.
My guess is you somehow have the carburetor installed incorrectly; without a sufficient supply of gasoline, a huge vacuum leak will keep the engine from running.
Since you seem to have both - lots of gas and lots of air - this is pointing at the carburetor.
Old Feb 8, 2015 | 11:01 AM
ctubutis's Avatar
ctubutis
Stated another way - the only way an engine can operate at 5,000+ RPM (WOT) is if it has enough gas + air combined with proper ignition timing to do it. Timing by itself doesn't supply gas & air; too much gas without enough air will flood it; too much air without the gas doesn't produce a burnable mixture.
IOW, the only thing that can cause a WOT condition is just that - a wide-open throttle.
Perhaps the linkage is installed backwards, perhaps the butterfly valves on the bottom of the carb are stuck wide open.
Old Feb 8, 2015 | 11:38 AM
bcamill's Avatar
bcamill
OK, I will pull the carb and see if anything got stuck
Old Feb 8, 2015 | 01:34 PM
bcamill's Avatar
bcamill
OK, pulled the carb and all looked OK, except it was dumping fuel. Must be a bad valve or the float. Sending back to get replaced.
442tom
Jun 10, 2018 09:16 AM
apbtpetey
Mar 25, 2013 09:57 AM
Poppabear
Nov 16, 2010 06:57 PM
BandtChsr
General Automotive Discussion
Apr 16, 2007 09:02 PM
Billyboy501
Feb 19, 2003 07:33 AM
