Fast idle issues
Old Jun 9, 2018 | 02:48 PM
442tom's Avatar
442tom
Fast idle issues
Looking at a 1978 Ranger with 351M. Truck idles nicely in park but revs high in drive. A tap of the pedal settles it down, but wondering what I might be dealing with; vacuum leak, choke problem or timing chain (had a car once that had a bad timing chain that caused fast idle). Any ideas? Thanks!
Old Jun 9, 2018 | 03:20 PM
niko20's Avatar
niko20
Maybe a vacuum advance issue? Although I would expect it to behave the other way around if so....does it have a stock carb?
Old Jun 9, 2018 | 03:25 PM
442tom's Avatar
442tom
No - Edelbrock 4 bbl.
Old Jun 9, 2018 | 04:43 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Does carb have a good double throttle return spring? I'm surprised at times when I see guys running no throttle return spring at all. Could be sticky throttle linkage or butterflies. I'd spray it down really good with carb cleaner, inside and out, while working the throttle and secondary butterflies. Let it sit 15 min or so before cranking. then try it. If I bought it, that carb would come off and get totally disassembled and rebuilt anyway.
Old Jun 10, 2018 | 09:16 AM
meangreen92's Avatar
meangreen92
Is the choke staying fully open upon warm-up? It sounds like your fast idle is kicking in when it shouldn't. Is the choke electric? Is it connected? Do those have provisions for the hot air tube which 'connects' to the manifold?
silar
Feb 22, 2015 07:02 PM
CropDusterMan
Feb 4, 2011 05:07 PM
1954F250
Sep 4, 2008 11:11 AM
BandtChsr
General Automotive Discussion
Apr 16, 2007 09:02 PM
pburress
Mar 20, 2006 05:00 PM
