Fuel Injector Replacement
Old Feb 7, 2015 | 01:09 AM
towme's Avatar
towme
My 2005 F-250 does not have power when the engine is cold. When the engine warms up then it seems fine. I believe that the fuel injectors need replacement. I was told that one cannot get new injectors. They are all re-manufactured. Is this correct? Also, this job is not for Do-it-yourselfers? I was quoted about $3,500 for parts and labor for all 8 injectors. Thank you all for your feedback.
Old Feb 7, 2015 | 05:47 AM
78fordman's Avatar
78fordman
Injector replacement is not too bad. If it is a stiction problem I would try polishing the spool valves.
Old Feb 7, 2015 | 06:29 AM
bismic's Avatar
bismic
Ford remanned injectors are highly recommended over the aftermarket ones.
Get a gauge system and monitor FICM voltages - it may not actually be the injectors themselves.
What oil and whose oil filter are you using, and how long do you go between oil changes?
Ever tried an oil additive (Rev-X or Archoil)?
Old Feb 7, 2015 | 12:44 PM
towme's Avatar
towme
From reading the comments on this site I have had a Scangauge installed for a couple of years now. My FICM voltage has been reading 47V to 47.5V with the engine cold or hot. I change the oil every 4000 to 5000 miles, using Ford OEM filter and Ford Diesel Oil 10W40. I have never tried any oil additive. I have heard of stiction before but I need to find out what this is since I am not much of a mechanic. I do most of the maintenance items like changing air filter, oil, oil filter, fuel filters, coolant flush, and tranny oil filter and fluid. I suspect that I need fuel injectors because I told someone about the symptom and they said I need new fuel injectors. Thank you for your feedback.
Old Feb 7, 2015 | 12:46 PM
bismic's Avatar
bismic
sounds like it is time for you to spend $3500+ then. best of luck.
Old Feb 7, 2015 | 12:54 PM
bismic's Avatar
bismic
This has probably been discussed before, but I can't find a Motorcraft 10W40 Diesel oil
Motorcraft® Motor Oils ? The Official Ford Parts Site | FordParts.com
Are you sure the oil you are using is 10W40 from Motorcraft AND carries the CI or CJ rating?
Old Feb 7, 2015 | 02:16 PM
r2millers's Avatar
r2millers
Not sure who "they" are and their qualifications but I'd take you truck to a local diesel mechanic and run a live scan for actual injector results. Some will do it without charge, knowing they'll get your business now or later.
Easy for someone to recommend new injectors when they don't need to do the buying. Stiction fix by cleaning the spool valves comes much cheaper and would probably fix the issue.
Old Feb 7, 2015 | 03:00 PM
Bite N Hold's Avatar
Bite N Hold
How do you polish the spool valves? Can it be done DIY?
Old Feb 7, 2015 | 07:33 PM
r2millers's Avatar
r2millers
Review this you tube video.
Old Feb 7, 2015 | 08:14 PM
towme's Avatar
towme
I am sorry, Bismic, the oil is 15W40 Motorcraft Super Duty Diesel Oil, not 10W40. Got this from Walmart. : )
I will look into the stiction problem. Thank you for the video, Bob.
Old Feb 8, 2015 | 06:10 AM
Bite N Hold
Ok good vid. So that shows how to dismantle the spool valve. 2 questions. How do you know if the stiction is caused by the sv and if it is, what do you do to fix it?
Old Feb 8, 2015 | 07:59 AM
MC5C's Avatar
MC5C
Stiction is usually misfiring or rough running when cold, goes away when warm. You don't mention rough running, just lack of power. As I understand it the engine management strategy does several things to restrict power and hasten warm up, this would include a different turbo vane setting strategy and transmission shifting strategy (uses a different fourth gear). I definitely notice this until the temps are above around 160 degrees. Could this be what you are experiencing?
Brian
Old Feb 8, 2015 | 11:05 AM
9228.bobcat's Avatar
9228.bobcat
Try 5w40 full synthetic and a bottle of archoil 9100. About $150 and it will help if not solve your issues. Oem oil filter as well.
Old Feb 8, 2015 | 04:52 PM
towme's Avatar
towme
The engine does not run rough when cold. It just didn't have power. When I give it more diesel, the engine acts like it's choking, or maybe this is classified as rough running? I have to ease up on the accelerator pedal then. But base on Brian's input, it could very well be that I have stiction. I need to find out how to get to the spool valves. : ) I think that if I do this spool valve cleaning first and it does not solve the problem then the problem is the injectors. Thank you all for your help!
Old Feb 8, 2015 | 05:12 PM
mhoefer's Avatar
mhoefer
The spool valves are in each injector. You need a proper scan tool reading the codes from each injector, and an injector contribution and balance test on the scan tool. You need to be doing proper diagnosis before changing parts, if you don't know enough about it before you go in you could be fixing the wrong thing. These are complicated modern motors, EGR valvle, sensor values could all cause parts of your symptoms. Spend the money on a proper diagnosis or you will be chasing your tail with your wallet open.....
