I was pokin around under the hood yesterday and saw oil around
the plug @ the oil pressure sensor on top of the oil galley. Is that
the ICP sensor? The truck has always had a hitch in starting right away,
if I wait a little bit after k.o. starts fine, too short or too long and and
it will crank about 3-4 sec. before firing. Could this sensor affect that?
icp = injection control pressure...basically it reads the pressure the ipr (injector pressure regulator) is putting in the heads.....
