A friend is down, most here suggested a new FICM, this is installed, but now has no oil presure at teh ICP sensor hole, there is NO OIL coming from it..
Is there a High presure resovoir that needs to be filled, or checked?
Assuming that no oil from the ICP sensor means that you see little-to-no pressure reading from a functional ICP sensor:
Is it possible that an aftermarket oil filter was used? If so (and the filter is too short), the drain valve at the bottom of the oil filter cannister will stay open and starve the HPOP.
I see from your other thread that it is an 05. I have read that the STC fitting can catastrophically fail - to the point that there is no base oil pressure. I suppose that would also mean that it would ultimately cause low/no pressure at the ICP sensor ....
