You guys find any PC579 sized LED bulbs for the map lights? I was looking on line and haven't found anything besides the stock bulbs. There has to be something out there.
Clay swapped LED's into the interior lights of his truck before I bought it a few years ago, Nick. Have you checked with him?
description is T10 3W 6- LG 5630 SMD LED High Power Wedge Cool White 6000K 194 168 501 W5W 12V from Amazon, (I"ll PM you the link), popped old bulb from the plastic housing, slipped this one in.
Did you replace the housing or solder them in? I went to my local napa and got pc579 bulbs that you can change the bulb out without soldering new ones in, cost about $4.50 each.
popped the old bulbs out, slid these in the stock housing, I did solder, but it's not needed the way those seat in there.
This was a huge difference in light over the stock incandescent, plus the current draw savings was pretty important, as I tend to spend a lot of time camping/with doors open.
Put these exact bulbs in our 04 X dome/map light tonight and they worked great. Removed original bulb from the plastic housing and slipped these in. They are a little loose fitting, (one fell back out when I snapped the plastic light cover back on) but otherwise very much of an improvement. Thanks for the help.
Just got them in both excursions last night and man what a difference!! Well worth it! I also went to napa and bought 4 of the PC579 lights and for what ever reason when you get those it changes it to a normal 194 bulb! Highley recommended!
