ford excursion tranny/electrical problems
Old Jan 26, 2015 | 07:02 PM
cmmiller53's Avatar
cmmiller53
Hey everybody, new here, for starters I drive a 2002 ford excursion lifted 10 inches on 37s, with a 7.3 in it, I had the transmission rebuilt in july, but recently started having temperamental issues.
For starters I put my edge evolution Cs on the truck for the first time since the rebuild about a month ago, and last week, the transmission started shifting extremely hard, and a few times my O/D light started blinking, I removed the chip and it was still shifting hard, and extremely slow into reverse, yesterday the CEL came on reading codes P0500 and P0732.
I also noticed today that when I turned my headlights(HID) on initially after startup, my speedometer dropped to 0 for 30 seconds, and the O/D light began flashing for 30 seconds, I'm truly stumped on what's going on and any input will be appreciated, I'm trying to sell the truck but I can't do that until I fix it, thank you
Old Jan 27, 2015 | 09:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
P0500 means the PCM didn't see an input from the vehicle speed sensor. P0732 means that when the trans was in second gear the gear ratio was incorrect. That could be a result of the P0500 code. I'd ignore the P0732 code unless it comes back.
The P0500 is caused by either a bad vehicle speed sensor on the rear axle, or damaged wiring between the sensor and the PCM.
bigwelder
Sep 28, 2014 07:27 PM
mikenkaren
Nov 6, 2008 12:13 PM
countrysF250
Apr 26, 2008 07:28 PM
Olds_442
Sep 4, 2007 05:02 PM
karkraft55
1983 - 2012 Ranger & B-Series
Dec 22, 2005 06:54 AM
