Rebuilt AOD woes
Old Jan 24, 2015 | 09:49 AM
Reed's Avatar
Reed
Rebuilt AOD woes
A few years back I had the original AOD in my 89 E-150 rebuilt. After the rebuild the gears are extremely loud and whine loudly in every gear.
Is there a source for new gears for an AOD? This transmission used to be almost silent but now the transmission gears are as loud as the engine. Any tips appreciated.
Old Jan 24, 2015 | 02:21 PM
85e150's Avatar
85e150
I may be FOS, but you should never have had "gear whine" out of an automatic. I would shop for a rebuilt trans. If your pan isn't full of metal, and if your trans is still working, you might want to call the Pope and apply for miracle review.
Old Jan 24, 2015 | 03:52 PM
Reed's Avatar
Reed
I agree, but I plunked down $2k on this rebuild and I m going to get as much out of it as possible.
Old Jan 24, 2015 | 07:09 PM
85e150's Avatar
85e150
Well sure run it till it drops, but to eliminate the whine will take another rebuild and probably a donor trans, so just keep your eye out for a decent replacement. '88-'93 are the preferred years.
Old Jan 24, 2015 | 07:21 PM
Reed's Avatar
Reed
Thanks. I have a rebuilt C-6 ready to go. I was contemplating a swithc to the 4r70W gearset, but everyone says to swap all the internals when switching the gears.
Old Jan 24, 2015 | 09:24 PM
jk080's Avatar
jk080
Transmission Rebuilder
If the gear train is failing it wont take long for signs of metal contamination like sticky valves and governor.
One thing to check is the mount, if its has failed or collapsed it can allow the case of the transmission to contact the crossmember. Sometimes this can make the sound of the gear train more noticeable. Years ago when Cadillac had the TH400 in them, the mount would collapse and the vehicle would sound like a school bus.
Old Jan 24, 2015 | 09:51 PM
Reed's Avatar
Reed
Will do. The mounts and u-joints are on my list of things to check since the van gets a wicked shimmy above 65.
Larryjr03
13
Jul 27, 2017 11:05 PM
jeff hogan
Apr 1, 2015 07:24 AM
8850HO
Mar 19, 2015 10:02 AM
nothinbutford
Jul 7, 2003 09:03 PM
