Ford AOD Transmission, rebuild or not
Dark syrupy fluid with chunks in the pan are good signs that the trans is toast. Other than that it's a crap shoot. The previous owner may have already dropped the pan, installed a new filter, cleaned off the magnet, wiped everything down, and installed new fluid. The new owner (you) would be none the wiser as to the condition of the internals of the trans. If you had the skills and tools to disassemble the trans, the only way to know for sure about the condition of the trans, then you probably would have already done it. Take it to a reputable rebuilder and he can give you the info you seek. Good luck.
Received 4,132 Likes
on
From what I've read there are good years of AODs and Bad. It looks as though you can improve the "bad" AODs by exchanging some of the internals. Not being a AOD GURU I'd opt to have the Pros rebuild it if a rebuild is in order.
I had a similar situation when I bought a supposedly rebuilt C4 trans off EBAY. It was toast, so I decided to try and rebuild it myself. I enjoyed rebuilding it very much. I only had one problem caused because the PO had a part in backwards, witch I put back in how I found it, backwards lol (the Haynes book didn't have a pic of how it went in) . Long story short, I took it to my local tranny shop, and the builder found the one part right away, double checked my work and charged a reasonable fee for it. I'm so glad that I chose to try, I learned a lot, and got a great feeling of accomplishment. MY 2cents is to try it, just get the best book available for your trans. and try. All that said, it's your truck, your time and money, and your decision of which transmission you want, so what ever you decide there will be support for you on FTE. Oh and in case you arnt aware, there is also a rear end, trans & clutch forum on FTE, https://www.ford-trucks.com/forums/forum69/there's a retired FORD Trans. engineer that is also very helpful. "Mark Kovalsky" is his FTE name, Best of luck on this tranny project. ROCK ON my friend
on
on
No... if it requires a controller it's not an AOD, that transmission has always been a 100% mechanical trans. There are several other Ford slushboxes that require an electronic controller but they have different designations.
jeff hogan
04-01-2015 07:24 AM
8850HO
03-19-2015 10:02 AM
Reed
01-24-2015 09:51 PM
dmc919
03-14-2007 07:29 PM
