95 explorer vibration..help
Old Jan 21, 2015 | 10:45 AM
66shadow's Avatar
66shadow
I just got a 1995 explorer from my father in law... I have noticed a vibration from 55 to 60 cannot figure it out.. Anyone else have this problem or know what might be causing it?
Don't want to spend a ton of money to fix....it is my daily driver to work
Old Jan 21, 2015 | 12:12 PM
shorod's Avatar
shorod
Often vibrations in a specific speed range are due to tire balance issues or tire defects. If the vibration can be noticed in the steering wheel, it's going to at least be an issue with the fronts. If the vibration is only in the body of the vehicle, the issue is with the rear. You could try swapping the tires front to rear to confirm the vibration changes with the wheel/tire location to confirm the issue is with either balance or the tires.
-Rod
linedog
2011 - 2019 Explorer
50
Sep 23, 2017 04:42 PM
FOWL1
Aug 15, 2012 03:47 PM
jllang2
2004 - 2008 F150
25
Oct 6, 2008 01:39 AM
CanuckXLT
Escape & Escape Hybrid
Apr 4, 2008 02:24 PM
karslake
Nov 26, 2005 12:38 AM
