2000 Ford Explorer Limited, electrical issues
Old Dec 3, 2014 | 12:34 PM
DNFH's Avatar
DNFH
Question 2000 Ford Explorer Limited, electrical issues
Hey there folks - new to this forum - recently bought a 2000 Ford Explorer Limited (V6, SOHC) - I've had Merc Mountaineers before - I'm loving this new car, except for a couple niggly electrical issues - chiefly - the central locking, and power seats - nothing works - the seats have no activity/heat/movement etc, and the central locking has no function - from the remote fob OR the door buttons - every unlock/lock has to be done manually with the key and/or pressing the locks down. I've read several threads with similar issues, for the locks, and for the seats, but not together. Has anyone else had similar failures?
Old Dec 3, 2014 | 01:27 PM
shorod's Avatar
shorod
Welcome to the forum!
For starters, have you checked all the fuses to make sure none are blown and confirmed that all relays are installed? Do the power windows work?
-Rod
Old Dec 3, 2014 | 01:53 PM
DNFH's Avatar
DNFH
Electrical stuff...
Also noticed the front cab lights don't come on (the back seat ones do) and the 'reverse sensor'-thingy doesn't work - again, nothing troublesome, just quirky..... the door locks also don't engage when putting the car into drive - the mountaineers did that - are Explorers supposed to do that too?
Old Dec 3, 2014 | 01:56 PM
DNFH's Avatar
DNFH
The power windows work just fine; and all fuses look intact - I've seen several posts about wiring corrosion where the conduit passes through the door - I'll look there next - thanks shorod!
Old Jan 21, 2015 | 10:44 PM
brzehentmaier's Avatar
brzehentmaier
Had a Expedition with the same problems. Pulled the kick panel drivers side and found 3 Heavily corroded connecters. Replaced connections and everything worked, even the key fob. Don't know if that helps but I hope so.
Bernie
Shovel7d1
Apr 22, 2014 11:25 AM
ptwohey
Aug 20, 2013 09:40 PM
luke21er
Feb 6, 2007 05:06 PM
