powder coating
Old Jan 19, 2015 | 08:16 AM
breezesboy's Avatar
breezesboy
powder coating
So I know nothing about powder coating. I would like to have my frame powder coated, but I don't want to take off the cab (more work than I think im capable of). Can I leave the cab on and still get the frame coated (minus the rails the cab sits on)?
Old Jan 19, 2015 | 09:01 AM
TylerJ150's Avatar
TylerJ150
That's a negative ghost rider, powder coat has to be cured and they do that by baking it in a large oven so to speak
Old Jan 19, 2015 | 06:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
TylerJ150 is correct, after the powder coating is sprayed on, the part is baked in an oven to cure it.
In your case I would clean the frame rails real well and spray a couple of coats of Rustoleum Rusty Metal Primer then spray a couple of coats of a good semi-gloss black and let it dry for a couple of days.
I'm not a big fan of powder coating something like a frame. I've seen too many cases of the powder coating prep being done improperly and rust starts to build up underneath the coating, this causes bubbles to develop in the coating. You won't know until the damage starts to form. The only correct repair is to strip the truck down to the bare frame and have it done all over.
Also, if the coating becomes chipped or cracked, there's no way to repair it and make it look good. With paint, if it becomes damaged, it's relatively easy to repair the damage.
Old Jan 20, 2015 | 05:23 AM
Bud Mud's Avatar
Bud Mud
Great point Mike, under coating will do the same.
Im just getting into powder coating at my home shop, doing as much as i can on the new engine, the balancer is painted though.
Old Jan 20, 2015 | 06:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by Bud Mud
I'm just getting into powder coating at my home shop, doing as much as i can on the new engine, the balancer is painted though.
Those pieces look great Bud, nice job.
I tried to post these last night but couldn't get them to go through .
To the OP, I sprayed my frame like I described in the post, here's how it turned out.
Old Jan 21, 2015 | 05:59 AM
Bud Mud's Avatar
Bud Mud
Mike o0o0o0o your frame turned out great,id be more than happy with that.
Snowking
Jan 28, 2007 08:27 PM
79f150TX
Paint & Bodywork
Sep 10, 2006 07:06 PM
77460ford
Paint & Bodywork
Dec 21, 2005 10:07 PM
DeckedoutF150
Paint & Bodywork
Feb 12, 2005 09:25 PM
WRECK
Sep 12, 2003 08:53 PM
