Help ID rears
Old Jan 15, 2015 | 05:21 PM
Johnny Be Cool's Avatar
Johnny Be Cool
Help ID rears
1974 F-250 4x4. Can you tell me what rears are on this. I was told by the PO that it has Dana 60's front and rear, but they look small compared to my 1999 F350.
Old Jan 15, 2015 | 06:40 PM
tbear853's Avatar
tbear853
Front looks to me like a Dana 44, rear looks like a Dana 60 ..... rear axle vent tube is broke off too.
Old Jan 15, 2015 | 07:11 PM
tabascom16's Avatar
tabascom16
The rear is a D60. The rear D60 is nothing to brag about. Thin axle tubes and small diameter axle shafts.
I can't make a judgement call on the front. A picture of the steering knuckle on the front will conclusively tell if it is a D60. Ball joints, it is a D44. King pins it is a D60. Where the top ball joint would be on a D44 the D60 has a large cap with 4 bolts holding it down.
Old Jan 15, 2015 | 09:41 PM
Johnny Be Cool
Here's another picture of the front end. Can you with that tell if it's a 40 or 60.
Old Jan 15, 2015 | 09:42 PM
HIO Silver's Avatar
HIO Silver
Gee whiz.... I'd scrape off the gunk and read the axle stampings and decode the BOM number.
Differential Identification | West Coast Differentials
Old Jan 15, 2015 | 11:14 PM
Johnny Be Cool
This is what I found Dana 44 on Left, Dana 60 on Right.
Could this be right?
Old Jan 15, 2015 | 11:58 PM
rockittsled's Avatar
rockittsled
Crawl up under there and look for the info stamped, cast, and tagged on the axles for items 1 thru 5 on the image above
Old Jan 16, 2015 | 04:30 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I say very common D60 rear, and for the front it looks like a 74-75.5 Ford low pinion, drivers side closed knuckle, drum brake with 30 spline inners, 19 spline outers, small ujoints and weak knuckles D60.
But I am wrong all the time, so go here to double ck me.
BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
You can also measure the outer hub diameter, D60 is bigger than a D44 and D44 diff cover has smaller bolt heads that a D60.
Old Jan 16, 2015 | 09:12 AM
Johnny Be Cool
77&79F250- I'm not experiencing any problems w/ the front rear. What inherent problems are there? Are you saying that the front year should be changed out. I was thinking later in time to switch to a disc front year.
Old Jan 16, 2015 | 09:34 AM
77&79F250's Avatar
77&79F250
It is good enough for Ford in the day and for a DD now days, but if you wheel it hard there are better axles to use, that's all.
Old Jan 16, 2015 | 10:22 AM
Johnny Be Cool
On those closed knuckles, is there any maintenance, such as putting wheel bearing grease on the exposed section of the ball?
Old Jan 16, 2015 | 10:50 AM
77&79F250's Avatar
77&79F250
Not that I know of, I hear those closed knuckles are prone to leak on that main scraper seal...
Check your PM box.
lanceh13
Nov 17, 2005 11:08 PM
cheez67
Nov 5, 2005 10:41 AM
lilpig88
Mar 24, 2004 09:52 PM
big bogger
Mar 7, 2004 08:56 PM
rtweekle
Apr 29, 2003 10:00 AM
