diff id
Old Nov 4, 2005 | 12:03 AM
cheez67's Avatar
cheez67
Question diff id
i have a 1973/12 month build date f250 i am trying to id the front and rear
diffs any good sites to help me out i believe the front to be a 44 and rear to be
70 but am unsure
Old Nov 4, 2005 | 12:29 AM
Matts72's Avatar
Matts72
Should be a Dana 44 front and 60 rear...
You can tell on the front if it has King Pins its a Dana 60, if it has Ball Joints its a Dana 44...
A 60 and 70 rear are undistinguishable, a 70U rear is a high pinion rear with a goofy looking housing.
Somebody here should be able to post a VIN decoder link, I lost my hard drive a month or so ago and lost all that neato stuff.
Welcome to FTE
Old Nov 4, 2005 | 08:06 AM
rakent's Avatar
rakent
A '73 F250 4wd should have a Dana 60 rear and either a Dana 44-6CF or 44-6CF-HD front axle. Both front axles had closed knuckles and 12" drum brakes, the primary difference was in the size of the outer components. The HD axle had about a 3550lb GAWR, the standard axle had about a 3300lb GAWR. You can tell the difference by looking at the size of the lockout hubs - the standard axle had a tapered hub with a 1/2 ton sized lockout, the hubs on the HD axle weren't tapered and have huge lockouts. You can also count the number of bolts holding the wiper seals to the closed-knuckle ball on back side of each hub, wiper seals on the HD axles will have 12 bolts, the standard axles have 8 (I think).
I don't think that a true Dana 60 front end was a regularly available option in '73.
Hope this helps.
Old Nov 4, 2005 | 11:28 PM
Matts72's Avatar
Matts72
You are probably right... I've seen so many hacked up trucks with parts from different years, its not even funny...
Old Nov 5, 2005 | 10:41 AM
MBBFord's Avatar
MBBFord
What they said. If your also looking to find out the gear ratio, and if it has a track lock(limited slip), then check the tag of the bolt covers and show the numbers on here for some help with that.
kengarchow
Feb 24, 2015 01:00 AM
427ford
Jan 2, 2010 12:15 PM
Altitude
Dec 29, 2008 12:11 PM
Storm
Oct 9, 2007 08:24 AM
ray
Oct 27, 1999 12:22 AM
