need axle identification help
Old Mar 24, 2004 | 02:49 PM
lilpig88's Avatar
lilpig88
i'm looking at a pre77 3/4 ton 4x4. the rear axle is a dana 60, but i cannot look in the door for the weight so i need to know how i can tell if the front axle is a 44hd or 60. it is the kind where the u joints are enclosed and that's all i've got so far. i will try to get some tag numbers, but if i can't is there any way to tell a 60 front axle from a 44?
Old Mar 24, 2004 | 09:09 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Most Dana 44's used ball joints. Most Dana 60's used kingpins. Measure the size of the rear cover. If iit's a 60 front axle, the cover will be the same size as the rear. If it's a 44, it should be smaller. Also, on Dana axles, the model # is cast into the housing, usually on a lower corner viewable from the cover side. If all else fails, look up the bill of materials number on the axle on the Dana website www2.dana.com/expert It's a 6 or 7 digit number if I remember correctly.
Old Mar 24, 2004 | 09:52 PM
lilpig88's Avatar
lilpig88
i found a number cast in the lower lefthand part of the cover.
it is: 87070
does this help anyone?
Radster
Dec 5, 2016 01:20 PM
ZarK-eh
24
Aug 2, 2015 12:28 PM
GTBksRule
Jun 21, 2005 08:08 PM
75FordF-250
Apr 8, 2004 10:16 PM
Hardcore4x4er
Mar 18, 2004 11:46 PM
