Power Issue
Old Feb 7, 2015 | 06:22 PM
Kane96's Avatar
Kane96
Sorry, I misread the procedure. I just read it again and it says the far left and far right should be 48v. Which my far right was reading 48v but the far left wasn't reading anything at all.
Old Feb 7, 2015 | 06:37 PM
Rusty Axlerod's Avatar
Rusty Axlerod
If you remove the cover and see four screws, only one screw should have 48v, the one on the right (driver side).
If you remove the cover and see seven screws, only one screw should have 48v, the one on the left.
Old Feb 10, 2015 | 07:58 AM
Kane96's Avatar
Kane96
I just talked to a guy I worked with, and he said he had the same problem, and figured out it was his IDM. I guess he said he sprayed ether in the air port to start it up and keep it running. Is this something I should look more into.? If so, please give me some more details about it.
Old Feb 10, 2015 | 08:14 AM
Rusty Axlerod
IDM (Injector Driver Module) is another name for FICM. It's the same part. Ether is a bad idea on a 6.0 due to glow plug and cylinder head prechamber design. It can damage your engine or hurt you.
Old Feb 10, 2015 | 08:21 AM
Rusty Axlerod
Did you change the fuel filters? If so the next step would be to check fuel pressure or use an OBDII monitor to verify fuel injector pulse width to verify injectors are trying to squirt. (When it shuts down or won't start)
Checking for codes could be helpful too. You can have a stored fault code without the check engine light being on.
Old Feb 17, 2015 | 10:12 AM
Kane96's Avatar
Kane96
So I broke down and took it it to a shop. They found a silicone like substance in the oil cooler valve. Any idea what could cause this.? I am also going to look into getting the oil cooler bulletproof kit. Any Advice on where to go and what to get.?
flydaddy
Jan 10, 2014 05:07 PM
98SurplusExpy
Sep 21, 2013 12:01 AM
ke6zmy
Feb 18, 2013 11:30 AM
ACEN
Aug 18, 2012 11:08 PM
Fulthrotl
Aug 2, 2012 01:41 AM
