Offroad & 4x4
warn 4x4 hubs
Old Jan 15, 2015 | 08:26 AM
drewdole's Avatar
drewdole
warn 4x4 hubs
on my 1993 f250 can anybody give me the rundown on adjusting the wheelbearings and what size tools i need for the warn 4x4 hubs
Old Jan 15, 2015 | 07:28 PM
Ford_Six's Avatar
Ford_Six
Moved from the garage and workshop forum, you should get some better info here in the 4x4 section.
Old Jan 15, 2015 | 09:57 PM
Nothing Special's Avatar
Nothing Special
Nothing much needed for the hubs. The right size Allen wrench to remove the screws that hold the outer cap on. The newer Warn hubs I've had used a wave ring to hold the outer hub body in the wheel hub. That comes out pretty easily with a needle nose pliers. The older ones used a wire retainer. That was trickier to remove with a couple of small screwdrivers. The only "specialty" tool needed is a large snap ring pliers to remove the snap ring on the end of the axle stub.
To remove or adjust the wheel bearings you'll need a spindle nut wrench. If you have a Dana 44HD you probably need one with four prongs, a Dana 50 probably needs 6. You can get either at a NAPA or any similar store.
Old Jan 16, 2015 | 05:23 AM
tjc transport's Avatar
tjc transport
i ain't rite
that pretty much covers it. you will need to know what axle you have to get the proper spindle nut.
and if you have a Dana 50, DO NOT get the one that says it will work on both the 44 and 50, because it will not.
Old Jan 29, 2015 | 10:39 AM
3Mfarris54's Avatar
3Mfarris54
The socket that works on the 10.25 rear will work on the Dana 50. Napa stocks this piece.
green_95
May 20, 2016 02:54 PM
Spktyr
13
Oct 26, 2013 12:12 PM
mhorn0817
28
Jul 1, 2011 09:18 PM
muckypaws
Sep 25, 2007 03:43 AM
mikewalsh1
Apr 4, 2005 05:59 PM
