77 ford Highboy
Old Jan 11, 2015 | 04:24 PM
Randar's Avatar
Randar
77 ford Highboy
Damn oil pan gasket. Looks like I have to lift engine out for this. It's a 390 in it, and the pan will not come off
Old Jan 11, 2015 | 04:28 PM
1972RedNeck's Avatar
1972RedNeck
I have pulled the pan off of a couple FE's in dentside Highboy's. Is yours a rear sump? if yes, it should come off with ease. If no, it should come off with ease. What is keeping your pan from coming off? There is nothing really under the engine on a stock highboy (except the axle but you can put the frame on jack stands - but you don't have to).
Old Jan 11, 2015 | 04:32 PM
Randar's Avatar
Randar
The deep part of the pan is in the front , the oil pump hangs low. Looks like I can reach in and drop the pump but am worried that's a gong show to put back on
Old Jan 11, 2015 | 04:37 PM
Randar's Avatar
Randar
Yea I could try to raise the frame. Good call. Cuz the pan is resting on axle
Old Jan 11, 2015 | 04:53 PM
co425's Avatar
co425
Going to be more of a challenge with the wrong pan in your truck. You may be able to get away with it if you make some tall stands for under the frame. That way you can drop the axle out of the way.
karjunkie
Jun 21, 2013 07:49 PM
jhaas63
Feb 3, 2013 07:58 PM
Ford_Six
Jan 1, 2012 12:23 AM
avenges
Jul 26, 2009 06:05 PM
4fords
Apr 13, 2006 08:09 PM
