2005 Expedition
Old Jan 10, 2015 | 12:46 PM
Jag57's Avatar
Jag57
Question 2005 Expedition
help!! Just made it back from out of state hunting trip,driving to get new tires.And heard a bump sound , Driving about 40 mph and tack jumped from around 1800 rpm to 4500. Engine' smooth and parameters good . However will drive in low and 2 nd gear approximate 25 mph. When select drive will not shift into high without slipping an rapid rpm increase. Currently 135k service record's and general appearance were well maintained Any susgestions
Old Jan 10, 2015 | 01:33 PM
jk080's Avatar
jk080
Transmission Rebuilder
Its not good, there is going to be a problem with the direct drum inside the transmission. The direct drum is used in third and forth, either the clutches failed or the splines for the drum are stripped. Bottom line it will have to be disassembled to repair it. Its a common failure spot with that tranny.
Old Jan 10, 2015 | 03:53 PM
Jag57's Avatar
Jag57
Thumbs up Direct drive drum failure
Thank you for ur reply: I've rebuild a few c-4 and r-700 back in the day,Don't think I'll attempt this one thought it might be damage drum seal ,clutches etc.I was actually up in ur neck of woods,Oglethorpe county,was lucky to make it back.Great place to live, use truck to pull mid size flats boat all over south fl,.will guess Remanufacture over rebuild. A lot of less than quality shop herein Miami Tks again
Jinskeep3983
Sep 6, 2013 10:58 PM
hosejockey61
Nov 16, 2011 11:25 PM
Flanger
Jan 1, 2008 10:07 PM
mhare
Dec 5, 2007 01:53 PM
arcturner
Jan 26, 2005 01:12 PM
