Stuck on PAS
Old Jan 9, 2015 | 07:12 AM
sammie0126's Avatar
sammie0126
Stuck on PAS
I got a stuck and screaming parking aide sensor. Hit reverse and it its screaming full bore. Good news is I installed that manual override button last year for use when hitching the trailer, so for now I have the entire thing shut off. So I read some on this issue on the forums and have tried to listen for the one that's clicking, don't hear anything clicking, cleaned them all. Any other ideas on electrical issue that could cause this or how I trouble shoot to narrow down the bad guy? Two of them are pretty easy to get out the other two are a PITA so I had to have to pull them all. Especially with it being below zero, even the garage heat full on is barely above freezing.
Old Jan 9, 2015 | 07:18 AM
JuanHuevos's Avatar
JuanHuevos
I know on my I couldn't hear the clicking but I could feel them vibrating. Did you trying actually touching them?
Old Jan 9, 2015 | 07:20 AM
ithaca1230's Avatar
ithaca1230
I had a problem with one of mine for a while. ended up buying 20 of them from ebay for the price of one oem. Now they work again PM me and I can give you info on replacing them.
sammie0126's Avatar
sammie0126
Nope I will give it a try today. Did you have someone hold it in reverse while you felt them? Thanks
Old Jan 9, 2015 | 07:28 AM
JuanHuevos's Avatar
JuanHuevos
I put mine in reverse with the engine off and the parking brake on. They still work even with the engine off and you can really spend time trying to find the bad one. Not having the engine rumble and vibrate the truck really helps too.
Old Jan 10, 2015 | 02:48 AM
Stewart_H's Avatar
Stewart_H
I haven't read the thread, but was the one listed in the tech folder helpful at all?
Stewart
Old Jan 10, 2015 | 08:01 AM
sammie0126's Avatar
sammie0126
Stewart
Nope that's where I started, it is about having the light on because of a fault in system and the backup sensors failing to work or beeping once then stopping. My issue is it being stuck on. I am going to try some of the suggestions in this thread today now that it's above zero - or will be soon. Soon as I hit reverse the speaker screams like I am touching a wall with the bumper. No issues with the dash light.
slogward
Jul 18, 2018 11:46 PM
Powerstrokin_350
Apr 17, 2012 07:48 AM
aero993
Mar 11, 2010 05:17 PM
Dan'sF250
Mar 30, 2009 01:09 PM
chrisgraz
Sep 10, 2005 10:10 AM
