Speedo Cable Question?
Old Jul 20, 2003 | 05:12 PM
turbosek2's Avatar
turbosek2
I replaced my old FMX with a C6. I need a new speedo cable to slide into the C6.
If I buy an AutoMeter Speedometer, what kind of speedo cable do I need?
Thanks
Old Jul 20, 2003 | 05:56 PM
70fordguy's Avatar
70fordguy
As long as the Speedo uses 5/8 -18 threads you can go down to Autozone and spend $10.00 for the stock replacement cable. It's a little longer than the stock one but works out OK as long as you're careful with the routing. The only problem area I had was with the relationship of the cable core stop to the end of the factory speedo. When the speedo end was tightened down the core stop would bind up between the housing and the speedo. I drilled a 13/32 hole in a 1/4" flat washer to make a spacer and all is well. No more leaks and the spacer cures the bouncing needle.
march
Mar 9, 2014 08:10 PM
elkarcher1716
Feb 28, 2014 11:24 PM
Old_Crow
13
Jul 25, 2010 11:12 PM
Ongoingshow
18
Mar 18, 2010 11:04 PM
RTM
Feb 19, 2004 04:29 PM
