speedo cable question
Old Jul 22, 2010 | 06:53 PM
Old_Crow's Avatar
Old_Crow
OK, so I've confused every parts store in my little town, and the forum search was little help in this case. Your guys turn.
I've got a '61 F100 that I put an '82 C6 in. The speedo cable out of the '61 won't work because the transmission end is wrong. The speedo cable out of the '82 won't work because the speedo end is wrong.
Short of having a custom cable made(to the tune of like $60+freight)is there a cable out there that'll fit my truck?
Needs the threaded nut at the top and the adaptor that slides into the trans with the retaining tab on the bottom.
Old Jul 22, 2010 | 08:14 PM
66f-100's Avatar
66f-100
Get one for a '68 f100 with a c6 it will have the correct ends.
Old Jul 23, 2010 | 05:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7TZ17260AB .. Speedometer Cable-72.42" long / Obsolete
Applications: 1967 F100/250 352 MX Cruise-O-Matic / 1968/70 F100/350 360/390 C6.
Old Jul 24, 2010 | 05:40 AM
Old_Crow's Avatar
Old_Crow
Cool, thanks guys. The local O'reilly's shows to have it in stock(at least on the web), although I hope the pic on the web site is a generic pic 'cause it doesn't look right. Hope they can do better on this than the stupid mounting kit for my steering wheel that I ordered 3 weeks ago and still haven't seen.
Old Jul 24, 2010 | 05:54 AM
NumberDummy
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
DON SANDERSON FORD in Glendale AZ has 13 = 623-842-8762.
Sanderson will be cheaper, but...
You might contact GREEN (greensalescompany.com) and ask them to take pictures of it. Then, they'll pass them along in an email.
AFAIK, this is a free service.
Old Jul 24, 2010 | 07:08 AM
Wagatu's Avatar
Wagatu
I was looking for the same cable for my pu the other day, came up with Napa Part # BK 6151646. The ends look right in the book, but haven't ordered it yet. Gene
Old Jul 24, 2010 | 09:18 AM
66f-100's Avatar
66f-100
NPD carries the reproduction version of the cable.
Old Jul 24, 2010 | 01:08 PM
ms_michelle's Avatar
ms_michelle
My 65 F100 has a New Process four speed and has the transmission connection that is the push in type with the O-ring and the tab and bolt to hole it in. I think that is what you are describing. Of course the length may be a problem, I just don't know for sure on that.
Old Jul 24, 2010 | 06:29 PM
NumberDummy
C5TZ17260N (replaced C5TZ17260CH-64.80"long) .. Speedometer Cable-64.80" long / Obsolete
Fits 1965/71: F100/250 2WD w/3 Speed Manual // Warner T-18 & New Process 435 4 Speeds.
Fits: 1968/71 F350 w/Warner T-18 & New Process 435 4 speeds.
Old Jul 24, 2010 | 07:20 PM
Old_Crow's Avatar
Old_Crow
Ok, the cable that O'reilly's carries for a '68 F100 with a C6 won't fit my '82 C6. I looked at the cable and it's pretty much like the original '61 cable with treaded nuts at both ends.
The C6 I've got has the slide-in end with the retaining tab that is held by a little screw at the tranny end.
Michelle, I just looked at the manual trans cable on the O'reilly's site and I do believe you've hit on the solution. Of course, all the stores close to me have the auto trans one in stock, but have to order the manual trans one(which also costs more, of course). I think I'll wait until I get my steering wheel adaptor before I order something else.
Old Jul 24, 2010 | 08:33 PM
NumberDummy
Don't buy the cable until you are sure it's long enough.
Note that C5TZ-N is 64.80" long, while C7TZ-AB is 72.42" long.
As original: 1961 F100 3 on da tree: 69.82" long / w/overdrive or A/T: 76.24" long / w/T-98 4 speed 80.38" long.
Old Jul 24, 2010 | 08:57 PM
66f-100's Avatar
66f-100
The '68 cable should work, that's what I used on mine after putting in a C6. It has the push-in style end at the tranny and screw on end at the speedo. Maybe they pulled the wrong part?
Old Jul 25, 2010 | 06:30 AM
Old_Crow's Avatar
Old_Crow
The cable they pulled matched the pic of the same part# on the net listing. Maybe they've got thier listing backwards. Site's down right this minute for maintenance, but the criteria I used was '68 F100 V8 Automatic. This returns a pic of the cable with 2 nuts. If you switch the trans to Standard it returns a pic of the cable with the end I need.
I just looked at the Napa site and they list a cable with the ends I need that's 82" long.
I've got the original '61 cable and I'm gonna hook it up to the speedo today and use it to figure out how long a cable I need. Shoulda done that when I swapped it out, but I was more concerned with getting it out of my way at the time.
Heh, at least I'm not trying to come up with a cable that'll fit some off brand transmission.
Old Jul 25, 2010 | 11:12 PM
RJP66F100's Avatar
RJP66F100
In my 66, I'm using the cable that was hooked to my NP 435 in my current set up with C6. It has the ends like you need but it could stand to be an inch or two longer.
Matt Joines
Electrical Systems/Wiring
Jan 7, 2017 01:55 PM
ravens fan
Dec 18, 2015 09:21 PM
85_Blue
Aug 27, 2015 07:17 PM
Dai Sheep
Apr 25, 2015 04:13 PM
C Holmes
Dec 11, 2008 02:38 PM
