Tranny slams.
Old Jan 15, 2015 | 09:28 PM
  #31
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by subford
628 says your TC clutch has excessive slip.
That code will cause the trans to slam on the shifts. When this (and many other) codes are set the trans goes into failure mode and the line pressure is set high to reduce the likelyhood of further damage. This causes the shifts to slam.
I'd love to hear how it could be a wire or the computer. In my experience it is always a mechanical fault inside the torque converter or the trans itself.
Old Jan 16, 2015 | 03:35 PM
  #32
Truckin Bob's Avatar
Truckin Bob
Originally Posted by mousty
Just spent 100.00 to have it hooked up to a shop scanner. That is the codes they gave me. also said they talked to there tranny expert and the 628 code is the kiss of death for my tranny? I think its a wire or computer
Just for grins and YOUR peace of mind.........I'd pull the "computer" and take a look inside and see if there's any sign of swollen or leaking capacitors.
Here's what you'd be looking for: A9x ECM's (and same years ECM's) Failures Due to Age
IIRC there was a TSB that had to do with the cab dome light screws shorting the circuit (I think it was the in cab #8 fuse circuit) .....critical for the PSOM operation to feed the "computer" the proper VSS signal. Like I said, IIRC.
My 94' had a similar symptom.......random check engine light, trans going into "limp mode", and it turned out to be my "tapping into" the fuse box under the dash # 8 circuit with a "tap in fuse connector" which made the fuse slot sloppy (the fuse fit loosely causing an intermittent connection) in the fuse holder.
Are there ANY aftermarket devices (stereo, GPS, alarm, etc.) that have been hooked up to the fuse boxe(s) or tapped into either under the dash or under the hood ???????
Also, I seem to recall way back when reading that someone had problems with the heavier yellow wires going to the back of their fuse boxes....could have been under the hood or under the dash, I can't remember. They had found severe corrosion UNDER their fuse boxes (heavier yellow wiring) and was a pretty simple process to fix.
Those are some things that, if I were you, would check.
Yes, I know you've got some codes, but just tryin' to toss out some ideas for you.
Bob
Old Jan 20, 2015 | 08:25 PM
  #33
bunruh's Avatar
bunruh
I have a '94 F150 with E4OD transmission that would act like you described. Over a year ago I replaced the "Neutral Safety Switch" or Manual Lever Position Sensor (MLPS) and connector. Picked the part from Autozone, and hasn't jumped (or slammed) since then.
Old Jan 20, 2015 | 08:30 PM
  #34
mousty's Avatar
mousty
Stereo installed. Have also replaced neutral safety switch.
Old Jan 29, 2015 | 02:41 PM
  #35
mousty's Avatar
mousty
Update! Thought I needed new tranny! Nope! Found ground wire off and wrong filter in transmission. Been a week and no slamming! Just an FYI.
Old Jan 29, 2015 | 05:56 PM
  #36
rla2005's Avatar
rla2005
Glad to see it's working for you now
Old Jan 29, 2015 | 09:01 PM
  #37
Old Trusty's Avatar
Old Trusty
This thread sounds like an Anonomise HATE GROUP!
David Guenther
Jul 20, 2014 09:10 PM
eljefe007
May 30, 2013 03:32 PM
ExGMguy
Mar 24, 2009 09:37 PM
TECATE_CHASER
Feb 14, 2007 07:41 AM
bulldogcountry1
Apr 10, 2003 12:36 PM
