pulling codes 93 4x4
Old Apr 11, 2005 | 03:08 AM
TECATE_CHASER's Avatar
TECATE_CHASER
1993 f150 4x4 302 A4OD 83,000 o/d off light is flashing, only when the o/d is turned off. WOT 1-2 shift is hard more like a klunk. This started about 1,000 miles after taking out a hypertech chip. I`ve pulled the codes using the check engine light as in fordfuelinjection.com shows.....a TPS code voltage out of spec. ,o2 lean, and evp under .24 volts.
is there a way to pull codes off the the tranny? as the o/d light flashes only when the o/d is switched off like its a code but its kinda hard to count them out on the road. any helllppp??/
Old Feb 14, 2007 | 12:00 AM
croweagle's Avatar
croweagle
plug in a code reader
Old Feb 14, 2007 | 07:41 AM
projectSHO89's Avatar
projectSHO89
ALL fault codes are stored in the PCM. When you pull the engine fault codes, you also pull any STORED DTCs that also affect the tranny.
The factory service procedure has a specific procedure to follow to specifically test transmission function. Following it would likely be helpful.
Steve
branrobi
Jan 13, 2019 12:44 PM
2002exPSD
Feb 16, 2012 09:01 PM
cjben
Nov 29, 2009 01:33 PM
cjben
Nov 27, 2009 04:04 PM
