Pulled engine codes after edge insight install
Old Jan 8, 2015 | 10:11 AM
Kongerup's Avatar
Kongerup
How can I fix the baro issue?
Old Jan 8, 2015 | 12:20 PM
mustang_309's Avatar
mustang_309
Replace the sensor, I don't know its exact location so hopefully someone else will chime in.
Old Jan 8, 2015 | 01:43 PM
Money-Pit's Avatar
Money-Pit
Barometer sensor is located on the drivers side of the dash under steering wheel. Remove the access panel and look along the metal brace at the bottom of the opening toward the right near the Data Link Connector... it should be secured to the metal brace.
Old Jan 8, 2015 | 02:15 PM
Kongerup's Avatar
Kongerup
Thank you. What is affected by having a faulty baro sensor? Jive noticed my MPG is not where it should be.
Old Jan 8, 2015 | 02:23 PM
Money-Pit's Avatar
Money-Pit
That...I don't know. I haven't heard of one actually going bad. Maybe a dead fly is stuck in it?
Old Jan 8, 2015 | 03:49 PM
mustang_309
It would show a false high boost
as boost = MAP - BARO
Old Jan 8, 2015 | 04:29 PM
npccpartsman's Avatar
npccpartsman
And the BARO is basically the baseline for the other two since MAP and EBP (not used in your case) can both vary. The BARO sensor rarely goes bad, but it does happen. For reference you can check the national weather service for daily/hourly readings of the barometer to baseline your sensor. you'll probably have to convert it, of course.
Old Jan 8, 2015 | 06:30 PM
Kongerup's Avatar
Kongerup
I drove around all day on both city and highway today, about 150 mile round trip and the baro reading did not change at all. It remains on 12.5 whether the engine is idling, full throttle or cruising. It is the same with KOEO.
Old Jan 8, 2015 | 06:45 PM
mustang_309
And that is exactly what it should do as it is only reading barometric pressure and will only change with altitude.
Old Jan 8, 2015 | 06:47 PM
Kongerup's Avatar
Kongerup
The MAP fluctuated throughout the drive. If baro is working correctly, it should be within .5 of the MAP reading? Is that only with KOEO or while running too?
Old Jan 8, 2015 | 08:32 PM
mustang_309
That is only at KOEO.
Restlesswildman
May 21, 2013 08:46 PM
PoPs 03DEX
Aug 10, 2011 04:26 PM
bwilliam7
Sep 29, 2010 07:22 AM
f1001978
1978 - 1996 Big Bronco
Aug 25, 2004 07:12 AM
larbera76
Apr 12, 2002 07:35 AM
