Are early and late ICP sensors "interchangeable"?
Thanks again Aaron for the help with the fuel filter/regulator. It is on and the truck is running!
I am sorry for not providing enough information - I have a few "irons in the fire" this morning! I hate it when people do not post enough information and here I am starting the New Year out by doing it!
I am actually running the late model sensor in the truck right now (after installing a Termnator HPOP), but I am getting a P1211 code.
I was wondering if the range and scales were different enough to possibly be the cause of the code (before I spend the $125 on the appropriate sensor).
I did specify for the right year (1997), but not sure how it could be verified upon receipt - not real familiar with the later model 7.3's. I will go back and double check the IPR but I am pretty sure that it is correct (it is new from AutoNation and I always include the VIN when ordering parts for this engine).
I had some problems with the first HPOP I received (the pump flange surface was pitted and scratched quite a bit (was not my original pump that I received) and one of the fittings had a mangled thread) so I sent it back. The one that I received as a replacement had a severely damaged box when it arrived, but the pump itself looked OK, (but it was only wrapped in a few wraps of newspaper though).
I installed the second one.
etmooneyha21
16
05-06-2023 10:34 AM
